StarTech.com 100 Pack of Resealable Zip Ties - 6"
Quicklinx: FY20WS00 Mfr#: CBMZTRB6
£7.52 ex VAT
£9.02 inc VAT
100 Pack Medium Resealable UL TAA. These Small Resealable Cable Ties enable you to conveniently bundle and secure multiple cables, to route and organize them. 100 White cable ties are included, ensuring you'll have plenty on hand.
Reduce Waste and Keep Cables Organized
These plastic electrical cable wraps are resealable and reuseable, enabling you to remove the cable tie, and attach it to different bundle, add additional cables into your bundle, or reroute your cables at any time using the same cable ties, saving you time and cost, while reducing waste. The cable ties are 6" (150 mm) in length securing cable bundles up to 1.38" (35 mm) in diameter. They're quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
Industrial Strength
Made of durable Nylon 66 material, these cable ties are tough and flexible. They've been rigourously tested to support up to 50 lbs 22.7 kg of weight & are UL94 V-2 fire rated, UL Approved, and CE & Lloyd's Register Certified.
Available in Different Lengths and Colors
To suite any application, StarTech.com offers a wide selection of these cable ties in different lengths and colors:
100 Pack - 5 in. (125 mm) White Cable Ties (CBMZTRB5)
100 Pack - 5 in. (125 mm) Black Cable Ties (CBMZTRB5BK)
100 Pack - 6 in. (150 mm) White Cable Ties (CBMZTRB6)
100 Pack - 6 in. (150 mm) Black Cable Ties (CBMZTRB6BK)
100 Pack - 8 in. (203 mm) White Cable Ties (CBMZTRB8)
100 Pack - 8 in. (203 mm) Black Cable Ties (CBMZTRB8BK)
100 Pack - 10 in. (250 mm) White Cable Ties (CBMZTRB10)
100 Pack - 10 in. (250 mm) Black Cable Ties (CBMZTRB10BK)
These reusable cable wraps are backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Reduce waste and keep cables organized
    These plastic electrical cable wraps are resealable and reuseable, enabling you to remove the cable tie, and attach it to different bundle, add additional cables into your bundle, or reroute your cables at any time using the same cable ties, saving you time and cost, while reducing waste. They're quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
  • Industrial strength
    Made of durable nylon 66 material, these cable ties are tough and flexible.
StarTech.com 15cm(6") Reusable Cable Ties, 7mm(1/4") wide, 35mm(1-3/8") Bundle Dia. 22kg(50lb) Tensile Strength, Releasable Nylon Ties, Indoor/Outdoor, 94V-2/UL Listed, 100 Pack, White - Nylon 66 Plastic - TAA (CBMZTRB6) - cable tie - TAA Compliant
Cable tie
Packaged Quantity
100 (specifications are for single item)
0.8 cm
Thickness
1 mm
Length
15 cm
1.7 g
Product Material
Nylon 6-6
White
TAA Compliant
Packaged Quantity
Cable tie
Product Material
Nylon 6-6
0.8 cm
Length
15 cm
Thickness
1 mm
1.7 g
Enclosure Colour
White
Releasable, 22.7 kg min loop tensile strength, UL 94V-2 Rated, 35 mm bundle diameter
TAA Compliant
Shipping Width
28 cm
Shipping Depth
17 cm
Shipping Height
1 cm
Shipping Weight
179 g
-40 °C
85 °C
FY20 StarTech.com 100 Pack of Plastic Zip Ties With Screw Hole - 4" In Stock £4.14
