StarTech.com 100 Pack of Plastic Zip Ties With Screw Hole - 4"
Quicklinx: FY24WS00 Mfr#: CBMZTS10N4
10 In Stock
£4.03 ex VAT
£4.83 inc VAT
100 Pack Small Screw Hole TAA. These small cable ties with mounting hole enable you to conveniently bundle and secure multiple cables and route and organize them. 100 White cable ties are included, ensuring you'll have plenty on hand.
Secure & Bundle Your Cables with a Mountable Tie
These plastic electrical cable wraps feature a built-in mounting hole (3.2 mm in diameter) enabling you to bundle cables, then mount them to a wall. They are 4 in. (101.6 mm) in length securing cable bundles up to 0.98 in (25 mm). in diameter. They're quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
Industrial Strength
Made of durable Nylon 66 material, these cable ties are tough and flexible. They've been rigorously tested to support up to 18 lbs (8 kg) of weight & are UL94 V-2 fire rated, UL Approved, and CE & Lloyd's Register Certified.
Available in Different Lengths
To suite any application, StarTech.com offers a selection of these cable ties in different lengths:
100 Pack - 4 in. (101.6 mm) White Cable Ties with Mounting Hole (CBMZTS10N4)
100 Pack - 6 in. (152.4 mm) White Cable Ties with Mounting Hole (CBMZTS10N6)
100 Pack - 8 in. (203.2 mm) White Cable Ties with Mounting Hole (CBMZTS10N8)
These cable wraps are backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Secure and bundle your cables with a mountable tie
    These plastic electrical cable wraps feature a built-in mounting hole enabling you to bundle cables, then mount them to a wall. They're quick and easy to install or remove with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
  • Industrial strength
    Made of durable nylon 66 material, these cable ties are tough and flexible.
  • Built-in mounting hole
    Screw down and mount coax cable, RJ-11 telephone wire, audio, video, RJ-45 Cat5/Cat6 network, and USB cables to baseboards, wood trim, drywall, or masonry with a single screw or nail.
StarTech.com 10cm(4") Cable Ties with Mounting Hole, 2mm(1/16") wide, 24mm(7/8") Bundle Dia. 8kg(18lb) Tensile Strength, Nylon 66 Self Locking Ties with Screw Hole, UL Listed, 100 Pack - UL94 V-2 Rated - TAA (CBMZTS10N4) - cable tie - TAA Compliant
Cable tie
Packaged Quantity
100 (specifications are for single item)
0.3 cm
Thickness
0.1 cm
Length
10.16 cm
0.4 g
Product Material
Nylon 6-6
White
TAA Compliant
Packaged Quantity
Cable tie
Product Material
Nylon 6-6
0.3 cm
Length
10.16 cm
Thickness
0.1 cm
0.4 g
Enclosure Colour
White
UL 94V-2 Rated, 25 mm bundle diameter, 8 kg min loop tensile strength, 3.2 mm mounting hole size
TAA Compliant
Shipping Width
20 cm
Shipping Depth
12.5 cm
Shipping Height
1 cm
Shipping Weight
45.31 g
