100 Pack Medium Steel Nail TAA. These single nail cable clips secure cables to the wall to route and organize them. 100 White cable clips are included, ensuring you'll have plenty on hand.
Secure Your Cables with an Included Steel Nail
These electrical cable clips with steel nail enable you to bundle cables while mounting them to a wall. They hold cables from 0.20 in. (5 mm) to 0.28 in. (7 mm) in diameter. They're quick and easy to install, remove and reuse, with a .08 in. x 0.98 in. (2 mm x 25 mm) steel nail included that secures and mounts it to the wall - perfect for organizing and routing network cables, power cables, or other cables at your home or office.
Industrial Strength
Made of durable PE material and featuring a galvanized steel nail, these cable clips ensure a strong bearing capacity and are corrosion resistance and suitable for securing cable bundles to wood, drywall and masonry.
Available in Different Sizes
To suite different application, StarTech.com offers a variety of single and double nail cable clips:
Medium Single Steel Nail Cable Clips - 100 Pack (CBMNMCC2)
Large Single Steel Nail Cable Clips - 100 Pack (CBMNMCC3)
Extra Large Single Steel Nail Cable Clips - 100 Pack (CBMNMCC4)
Medium Double Steel Nail Cable Clips - 100 Pack (CBMDNMCC1)
Large Double Steel Nail Cable Clips - 100 Pack (CBMDNMCC2)
These cable clips are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Reduce clutter
Secure coax cable, RJ11 telephone wire, audio, video, RJ45 CAT5/CAT6 network and USB cables to baseboards and wood trim to reduce clutter. Suitable for wood, drywall and brick wall surfaces. -
Secure your cables with included steel nail
These cable clips with steel nail enable you to route cables while mounting them to a wall. They're quick and easy to install, remove and reuse, with steel nail included that secures the bundle and mounts it to the wall - perfect for organizing and routing network cables, power cables, electrical cables or other cables at your home or office. -
Industrial strength
Made of durable PE material and featuring a galvanized steel nail these cable clips ensure a strong bearing capacity and are corrosion-resistant and suitable for securing cable bundles to wood, drywall, and masonry.
- StarTech.com 100 Pack Cable Clips with Nail, Reusable, Nail-in Clamps, Wire Holding Clips, CAT5/CAT6 Ethernet Cord/AV/Coax Cable Fasteners, Brick/Drywall Mounting Cable Tacks, White, TAA - 1"(25mm) Steel Nail (CBMNMCC2) - cable clips with nails - TAA Compliant
- Product Type
- Cable clips with nails
- Packaged Quantity
- 100 (specifications are for single item)
- 0.595 cm x 1.098 cm x 2.535 cm
- 0.9 g
- Product Material
- Polyethylene
- White
- TAA Compliant
- 2-year warranty
- Packaged Quantity
- Product Type
- Product Material
- Polyethylene
- 0.595 cm
- 1.098 cm
- 2.535 cm
- 0.9 g
- Enclosure Colour
- White
- 2 mm x 30 mm nail size, 5 - 7 mm clamping diameter
- TAA Compliant
- Shipping Width
- 12.2 cm
- Shipping Depth
- 9.9 cm
- Shipping Height
- 2.3 cm
- Shipping Weight
- 87.1 g
- Limited warranty - 2 years
