StarTech.com 100 Pack of Double Nail Mounted Cable Clip - Large
Quicklinx: FXZRWS00 Mfr#: CBMDNMCC2
£5.66 ex VAT
£6.79 inc VAT
100 Pack Large Steel Nails TAA. These double nail cable clips secure cables to the wall to route and organize them. 100 White cable clips are included, ensuring you'll have plenty on hand.
Secure Your Cables with Two Included Steel Nails
These cable clips with two steel nails enable you to route cables while mounting them to a wall or ceiling. They feature internal dimensions of 0.74 in. (18.7 mm) x 0.31 in. (8 mm). They're quick and easy to install, remove and reuse, with two 0.07 in. x 1.22 in (1.86 mm x 31 mm) steel nails included that secure the bundle and mounts it to the wall - perfect for organizing and routing network cables, power cables, electrical cables or other cables at your home or office.
Industrial Strength
Made of durable PE material and featuring 2-galvanized iron nails these cable clips ensure a strong bearing capacity and are corrosion resistant and suitable for securing cable bundles to wood, drywall and masonry.
Available in Different Sizes
To suit different applications, StarTech.com offers a variety of single and double nail cable clips:
Medium Single Steel Nail Cable Clips - 100 Pack (CBMNMCC2)
Large Single Steel Nail Cable Clips - 100 Pack (CBMNMCC3)
Extra Large Single Steel Nail Cable Clips - 100 Pack (CBMNMCC4)
Medium Double Steel Nail Cable Clips - 100 Pack (CBMDNMCC1)
Large Double Steel Nail Cable Clips - 100 Pack (CBMDNMCC2)
These cable clips are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Secure your cables with two included steel nails
    These cable clips with two steel nails enable you to route cables while mounting them to a wall or ceiling. They're quick and easy to install, remove and reuse, perfect for organizing and routing network cables, power cables, electrical cables or other cables at your home or office.
  • Industrial strength
StarTech.com 100 Pack Cable Clips with Nails, Two Steel Nails, Reusable Nail-in Clamps, Brick/Drywall Cable Fasteners, Ethernet Cord/AV/Coax Cable, PE Plastic Mounting Cable Tacks, White - 1-1/8"(31mm) Nails/TAA (CBMDNMCC2) - cable clips with nails - TAA Compliant
Cable clips with nails
Packaged Quantity
100 (specifications are for single item)
2.855 cm x 0.962 cm x 3.138 cm
2.2 g
Product Material
Polyethylene
White
TAA Compliant
Packaged Quantity
Product Material
Polyethylene
2.855 cm
0.962 cm
3.138 cm
2.2 g
Enclosure Colour
White
18.7 x 8 mm inner dimensions, 1.86 mm x 31 mm nail size
TAA Compliant
Shipping Width
23.5 cm
Shipping Depth
18.5 cm
Shipping Height
1 cm
Shipping Weight
227.1 g
FXZR StarTech.com 100 Pack of Double Nail Mounted Cable Clip - Medium In Stock £4.96
