StarTech.com 100 Pack 8" Black Cable Ties
Quicklinx: FY1QWS00 Mfr#: CBMZT8B
Hurry, only 2 left in stock!
£6.46 ex VAT
£7.75 inc VAT
Express delivery Delivered on Tuesday
100 Pack Large 8" 203.2 mm Black Nylon 66 |94V-2 Fire & UL Rated TAA UL. These Large cable ties enable you to conveniently bundle and secure multiple cables, to route and organize them. 100 Black cable ties are included, ensuring you'll have plenty on hand.
Keep Cables Organized
These plastic electrical cable wraps are 8" (203.2 mm) in length securing cable bundles up to 1.6" (40.6 mm) in diameter. They're quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
Industrial Strength
Made of durable Nylon 66 material, these cable ties are tough and flexible. They've been rigourously tested to support up to 50 lbs 22.7 kg of weight & are UL94 V-2 fire rated, UL Approved, and CE & Lloyd's Register Certified.
Available in Different Lengths and Colors
To suit any application, StarTech.com offers a wide selection of these cable ties in different lengths and colors:
100 Pack - 4" (101.6 mm) Black Cable Ties (CBMZT4B)
100 Pack - 4" (101.6 mm) White Cable Ties (CBMZT4N)
1000 Pack - 4" (101.6 mm) Black Cable Ties (CBMZT4BK)
1000 Pack - 4" (101.6 mm) White Cable Ties (CBMZT4NK)
100 Pack - 6" (152.4 mm) Black Cable Ties (CBMZT6B)
100 Pack - 6" (152.4 mm) White Cable Ties (CBMZT6N)
1000 Pack - 6" (152.4 mm) Black Cable Ties (CBMZT6BK)
1000 Pack - 6" (152.4 mm) White Cable Ties (CBMZT6NK)
100 Pack - 8" (203.2 mm) Black Cable Ties (CBMZT8B)
100 Pack - 8" (203.2 mm) White Cable Ties (CBMZT8N)
1000 Pack - 8" (203.2 mm) Black Cable Ties (CBMZT8BK)
1000 Pack - 8" (203.2 mm) White Cable Ties (CBMZT8NK)
100 Pack - 10" (254 mm) Black Cable Ties (CBMZT10B)
100 Pack - 10" (254 mm) White Cable Ties (CBMZT10N)
1000 Pack - 10" (254 mm) Black Cable Ties (CBMZT10BK)
1000 Pack - 10" (254 mm) White Cable Ties (CBMZT10NK)
These cable wraps are backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Keep cables organized
    These plastic electrical cable wraps are quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
  • Industrial strength
    Made of durable Nylon 66 material, these cable ties are tough and flexible. They've been rigorously tested to support up to 50 lbs 22.7 kg of weight & are UL94 V-2 fire rated, UL Approved, and CE & Lloyd's Register Certified.
StarTech.com 20cm(8") Cable Ties, 4mm(1/8") wide, 55mm(2-1/8") Bundle Diameter, 22kg(50lb) Tensile Strength, Nylon Self Locking Zip Ties with Curved Tip, 94V-2/UL Listed, 100 Pack, Black - Nylon 66 Plastic - TAA (CBMZT8B) - cable tie - TAA Compliant
Cable tie
Packaged Quantity
100 (specifications are for single item)
0.8 cm 0.4 cm
Length
20.32 cm
1.25 g
Product Material
Nylon 6-6
TAA Compliant
Packaged Quantity
Cable tie
Product Material
Nylon 6-6
0.8 cm
0.4 cm
Length
20.32 cm
1.25 g
Enclosure Colour
UL 94V-2 Rated
TAA Compliant
Shipping Width
13.5 cm
Shipping Depth
32 cm
Shipping Weight
148.46 g
-40 °C
85 °C
FY1Q StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Small In Stock £7.67
FY1Q StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Medium In Stock £8.71
FY1Q StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Large In Stock £9.57
