100 Pack Extra Large 10" 254 mm White Nylon 66 |94V-2 Fire & UL Rated TAA UL. These Extra Large cable ties enable you to conveniently bundle and secure multiple cables, to route and organize them. 100 White cable ties are included, ensuring you'll have plenty on hand.
Keep Cables Organized
These plastic electrical cable wraps are 10" (254 mm) in length securing cable bundles up to 2.7" (68.6 mm) in diameter. They're quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation.
Industrial Strength
Made of durable Nylon 66 material, these cable ties are tough and flexible. They've been rigourously tested to support up to 50 lbs 22.7 kg of weight & are UL94 V-2 fire rated, UL Approved, and CE & Lloyd's Register Certified.
Available in Different Lengths and Colors
To suit any application, StarTech.com offers a wide selection of these cable ties in different lengths and colors:
100 Pack - 4" (101.6 mm) Black Cable Ties (CBMZT4B)
100 Pack - 4" (101.6 mm) White Cable Ties (CBMZT4N)
1000 Pack - 4" (101.6 mm) Black Cable Ties (CBMZT4BK)
1000 Pack - 4" (101.6 mm) White Cable Ties (CBMZT4NK)
100 Pack - 6" (152.4 mm) Black Cable Ties (CBMZT6B)
100 Pack - 6" (152.4 mm) White Cable Ties (CBMZT6N)
1000 Pack - 6" (152.4 mm) Black Cable Ties (CBMZT6BK)
1000 Pack - 6" (152.4 mm) White Cable Ties (CBMZT6NK)
100 Pack - 8" (203.2 mm) Black Cable Ties (CBMZT8B)
100 Pack - 8" (203.2 mm) White Cable Ties (CBMZT8N)
1000 Pack - 8" (203.2 mm) Black Cable Ties (CBMZT8BK)
1000 Pack - 8" (203.2 mm) White Cable Ties (CBMZT8NK)
100 Pack - 10" (254 mm) Black Cable Ties (CBMZT10B)
100 Pack - 10" (254 mm) White Cable Ties (CBMZT10N)
1000 Pack - 10" (254 mm) Black Cable Ties (CBMZT10BK)
1000 Pack - 10" (254 mm) White Cable Ties (CBMZT10NK)
These cable wraps are backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Keep cables organized
These plastic electrical cable wraps are quick and easy to install or remove, with adjustable tension and a basic one-piece design - perfect for organizing network cables, power cables, or other cables at your home or office workstation. -
Industrial strength
Made of durable Nylon 66 material, these cable ties are tough and flexible. They've been rigorously tested to support up to 50 lbs 22.7 kg of weight & are UL94 V-2 fire rated, UL Approved, and CE & Lloyd's Register Certified.
- StarTech.com 10"(25cm) Cable Ties, 1/8"(4mm) wide, 2-5/8"(68mm) Bundle Diameter, 50lb(22kg) Tensile Strength, Nylon Self Locking Zip Ties w/ Curved Tip, 94V-2/UL Listed, 100 Pack, White - Nylon 66 Plastic - TAA (CBMZT10N) - cable tie - TAA Compliant
- Product Type
- Cable tie
- Packaged Quantity
- 100 (specifications are for single item)
- 0.5 cm
- Thickness
- 1 mm
- Length
- 25.4 cm
- 1.8 g
- Product Material
- Nylon 6-6
- White
- TAA Compliant
- 2-year warranty
- Packaged Quantity
- Product Type
- Cable tie
- Product Material
- Nylon 6-6
- 0.5 cm
- Length
- 25.4 cm
- Thickness
- 1 mm
- 1.8 g
- Enclosure Colour
- White
- UL 94V-2 Rated
- TAA Compliant
- Shipping Width
- 38 cm
- Shipping Depth
- 13.5 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 195.83 g
- Limited warranty - 2 years
- -40 °C
- 85 °C
StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Small | In Stock | £6.48 |
StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Medium | In Stock | £7.56 |
StarTech.com 100 Pack of Self-Adhesive Cable Tie Mounts - Large | In Stock | £8.08 |
StarTech.com 100 Pack of Plastic Zip Ties With Screw Hole - 4" | In Stock | £4.03 |
