This TAA compliant 10-port industrial USB 3.0 hub gives you the scalability and power supply flexibility you need in harsh industrial environments, product, and repair labs, conference rooms or office workstations. With its rugged industrial-grade metal housing, it is designed to meet the advanced requirements of connecting a high number of devices in factories and office environments.
This industrial USB hub delivers reliable performance with a metal, heavy-duty housing. It supports wide-range 10-24V DC terminal block input, giving you the flexibility to power the hub as required, based on your own power input capabilities.
Perfect for factory environments, the rugged hub also supports a wide operating temperature range (0°C to 70°C) and offers surge and ESD protection to each USB port, which can help prevent damage to your connected devices.
Designed for a high volume of connections, this robust USB 3.0 hub offers 10 connection ports, for connecting more USB devices and peripherals.
The hub also supports USB battery charging specification 1.2, delivering up to 2.4A on any port to a maximum of 50W total, so you can charge your mobile devices faster than traditional USB ports allow.
With versatile installation options, you can install the hub where it's best suited for your environment. With built-in mounting brackets and included DIN mount rails, you can securely mount the USB 3.0 hub to most surfaces such as a wall, under a desk or rack.
It supports wide-range 10-24V DC terminal block input, giving you the flexibility to power the hub as required, based on your own power input capabilities. You have the option to power the industrial hub by connecting the hub directly to an outlet with the included external terminal block power adapter, for more convenient and flexible installation.
The rugged USB hub supports the full 5Gbps bandwidth of USB 3.0 and is backward compatible with previous USB devices. You can connect your legacy peripherals alongside your newer USB 3.0 devices without any disruptions.
                Efficient power managementWith an external power adapter delivering 65 watts, the hub provides adequate power for multiple devices, ensuring operation even under heavy loads.
                Versatile connectivity optionsFeaturing 10 Type-A USB 3.2 Gen 1 ports, this hub allows for seamless connection of various peripherals, enhancing productivity and connectivity.
                Robust environmental resilienceDesigned to operate in temperatures ranging from 0°C to 70°C and withstand storage temperatures between -20°C and 85°C, this hub can function reliably in various conditions.
                Secure device protectionWith 8KV contact discharge and 15KV air-gap surge protection, the hub ensures that connected devices are safeguarded against electrical surges and static discharge.
                Flexible installation optionsThis hub supports both DIN rail and wall mounting, allowing users to choose the most convenient setup for their workspace.
- StarTech.com 10 Port USB Hub with Power Adapter, Surge Protection, Metal Industrial USB 3.0 Data Transfer Hub, Din Rail, Wall or Desk Mountable, High Speed USB 3.1/ USB 3.2 Gen 1 5Gbps Hub - Windows/macOS/Linux (HB30A10AME) - hub - 10 ports - TAA Compliant
- Hub - 10 ports
- Subtype
- USB
- Ports
- 10 x USB 3.2 Gen 1
- Surge protection, UFP, DFP, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge)
- USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1
- Power
- AC 120/230 V
- 13.3 cm x 61.5 cm x 31.3 cm
- 350 g
- Black
- Localisation
- Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: ITB20D3250
- Hub - 10 ports
- Enclosure Type
- DIN rail mountable, wall-mountable
- Subtype
- USB
- Ports
- Processor
- X Genesys Logic GL3523
- 10 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type B
- Power Device
- External power adapter
- Power Provided
- DC 20 V - 3.25 A
- Voltage Required
- AC 120/230 V
- 65 Watt
- Black
- Included Accessories
- Mounting screws, DIN-rail mounting kit
- Cables Included
- 1 x USB host cable
- MTBF
- 126,106 hours
- FCC, REACH, USB Battery Charging Specification Rev. 1.2, UASP (USB Attached SCSI Protocol)
- TAA Compliant
- Localisation
- 13.3 cm
- 61.5 cm
- 31.3 cm
- 350 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 85 °C
- Designed For
- P/N: ITB20D3250
|  | StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £9.84 |
|  | StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.41 |
|  | StarTech.com 15 ft USB 3.0 A to B Cable M/M | In Stock | £79.70 |
|  | StarTech.com Universal DC Power Adapter for Industrial USB Hubs - 20V | In Stock | £40.15 |
|  | StarTech.com 4 Port USB C Hub 10Gbps - Metal Industrial USB Type-C Hub | In Stock | £109.99 |
|  | StarTech.com 4 Port USB C Hub 10Gbps | In Stock | £114.53 |
|  | StarTech.com Industrial USB 2.0 Hub | In Stock | £42.46 |
|  | StarTech.com Industrial USB 3.0 Hub | In Stock | £290.59 |
|  | StarTech.com Industrial USB 5Gbps Hub | In Stock | £314.99 |
