StarTech.com 10-Port USB-C Hub Self-Powered
Quicklinx: H3TXWS00 Mfr#: 10G8A2CS-USB-C-HUB
Type: USB Hub
Interface: USB-A, USB 3.1 Type C
Speed: 10Gbps
Ports: 10
Form Factor: External
17 In Stock
£109.54 ex VAT
£131.44 inc VAT
Add ten USB 3.2 Gen 2 (10Gbps) ports (8x USB-A, 2x USB-C) to a USB-C computer using this 10-Port USB-C Hub. The USB Hub is self-powered with an included power adapter. The USB Hub features Overcurrent Protection (OCP). OCP aids in preventing peripherals from overdrawing power, avoiding USB device dropouts and computers from shutting down unexpectedly. Support for Wake On USB enables USB communications, from devices connected to the hub, to take the computer out of standby or other power saving/sleep modes.
  • High Performance USB 3.2 Gen 2 (10Gbps) Hub
    The USB Hub shares 10Gbps of bandwidth from the USB host device, enabling high-speed data transfers for high-performance applications. The USB hub is backward compatible with previous USB versions, including USB 3.2 Gen 1 (5Gpbs), USB 2.0 (480Mbps), and USB 1.1 (12Mbps). It features eight USB-A ports and two USB-C ports. This combination of ports enables support for a wide range of modern and legacy USB devices, such as external storage devices (e.g., thumb drives, HDDs/SSDs), HD Cameras (e.g., webcams), mice, keyboards, and USB headsets.
  • Power and Charge USB Devices
    The USB hub is self-powered, using the 65W power adapter. The hub features two USB BC 1.2 ports (1x USB-A, 1x USB-C), each providing 2.4A (12W) of power simultaneously, making it ideal to charge battery powered USB devices like smartphones, and tablets, while also providing a data connection. These ports will provide power with or without a host computer connected, with support for both CDP (Charging Downstream Port) & DCP (Dedicated Charging Port) applications. The hub features seven USB-A, and one USB-C port that each provide the USB 3.2 standard of 0.9A (4.5W) of power. The included power adapter ensures that all ports will always provide specified power regardless of how many devices are connected.
  • USB-IF Certified Host Cable
    A high-quality USB-IF certified USB-C host cable is included. The cable features a screw-locking, connector to ensure a secure and reliable connection to the USB hub. The Thermoplastic Elastomer (TPE) cable jacket is softer and more flexible than PVC jacketed cables.
  • Plug-and-Play Installation
    The 10-Port USB Hub is OS independent supporting all operating systems, including Windows, macOS, ChromeOS, iPadOS and Android. Installation is automatic upon connection to a host computer. Mount the USB Hub to a wall, desk, or VESA mount, using StarTech.com hub mounts: SSPMSVESA or SSPMSUDWM.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The applicable software for this product is the USB Event Monitoring Utility. Use this utility to track and log any connected USB devices.
StarTech.com 10-Port USB-C Hub, 8x USB-A + 2x USB-C, Self-Powered w/ 65W Power Supply, USB 3.1 10Gbps Hub w/ BC1.2 Charging, Desktop/Laptop USB Hub with 3ft Locking USB-IF Certified Cable - USB Expansion Hub (10G8A2CS-USB-C-HUB) - hub - 10 ports
Hub - 10 ports
Subtype
USB
Ports
8 x USB 3.2 Gen 2 + 2 x USB-C 3.2 Gen 2
Performance
Data transfer rate: 10 Gbps
Self-powered mode, fast charging support, over-current protection, wake on USB, CDP, DCP
Battery Charging 1.2, USB 3.2 Gen 2, USB 3.2 Gen 1, USB 3.1 Gen 2, USB 2.0, USB 1.1
AC 110-240 V
11.5 cm x 8 cm x 3 cm
287 g
Space grey
Android, Apple iPadOS, Apple MacOS, Google Chrome OS, Microsoft Windows
Europe, North America, United Kingdom
Hub - 10 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Performance
X VIA VL822-Q7 / VL162
Status Indicators
Status
7 x USB 3.2 Gen 2 Type A , 1 x USB 3.2 Gen 2 Type A Battery Charging 1.2 , 1 x USB 3.2 Gen 2 Type C , 1 x USB 3.2 Gen 2 Type C Battery Charging 1.2 , 1 x USB 3.2 Gen 2 Type C host
External power adapter
Power Provided
DC 19 V - 3.42 A
AC 110-240 V
65 Watt
Space grey
1 x USB-C cable - 1 m
UASP (USB Attached SCSI Protocol), USB-IF, RoHS, WEEE, Thunderbolt 3, Thunderbolt 4, Plug and Play
Software Included
Connectivity Tools
11.5 cm
8 cm
3 cm
287 g
Limited warranty - 2 years , Technical support - assistance - lifetime
50 °C
0 - 95% RH (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
H3TX StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.28
H3TX StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA In Stock £14.31
H3TX StarTech.com 7-Port USB-C Hub, Self-Powered In Stock £101.47
Type: USB Hub
Interface: USB-A
Interface: USB 3.1 Type C
Speed: 10Gbps
Ports: 10
