StarTech.com 10 Gigabit Fiber SFP+ Transceiver Module SM LC
Quicklinx: C4ZHWS00 Mfr#: SFP10GLRST
Type: Modules
15 In Stock
£208.89 ex VAT
£250.66 inc VAT
Provide powerful, cost-efficient 10Gb Ethernet connections over single mode fiber with this Mini-GBIC module. This StarTech.com 10 Gigabit fiber SFP+ is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the SFP-10G-LR transceiver module, as well as other major brands of networking equipment.
It provides a dependable and cost-effective way to add, replace or upgrade the ports on your 10GBase-LR networking equipment, and it's backed by a lifetime warranty.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 10 Gigabit single-mode SFP+ is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco SFP-10G-LR SFP transceiver. The StarTech.com SFP+ transceiver module is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber SFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of 10 Gigabit networking devices.
Ideal for use in switches, routers and other networking equipment, the SFP+ provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SM fiber transceiver module supports Digital Diagnostics Monitoring, a maximum distance of up to 10 km (6.2 mi.), and maximum data rates of up to 10Gbps.
You can count on SFP10GLRST for reliable performance.
  • Reliable connectivity
    The SFP-10G-LR module supports wired connectivity technology, ensuring stable performance in networking applications.
  • Versatile compatibility
    This module is compatible with Ethernet 10GBase-LR cabling and works seamlessly with devices adhering to IEEE 802.3ae standards.
  • Durable operating range
    Designed to operate between 0°C and 70°C, this module is suitable for diverse environmental conditions.
  • Effective data management
    With the inclusion of full duplex mode, simultaneous data transmission and reception are facilitated, enhancing overall network efficiency.
  • Comprehensive monitoring
    The built-in Digital Diagnostics Monitoring Interface allows for real-time monitoring of module performance.
Startech Cisco SFP-10G-LR Compatible SFP+ Module, 10GBASE-LR, 10GbE SMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 10km, 1310nm, DDM, Cisco Firepower, ASR9000, C9300 - Lifetime Warranty (SFP10GLRST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10GbE
Max Transfer Distance
10 km
Cisco SFP-10G-LR
1.37 cm x 5.66 cm x 1.25 cm
20 g
P/N: PEX10GSFP
Plug-in module
Silver
Wired
Cabling Type
10GBase-LR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
Full duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3ae
1 x Ethernet 10GBase-LR - LC single-mode x 2
UL, FCC, RoHS, MSA
Cisco SFP-10G-LR
1.37 cm
5.66 cm
1.25 cm
20 g
Limited warranty - lifetime
70 °C
P/N: PEX10GSFP
C4ZH StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £35.41
C4ZH StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £295.64
C4ZH StarTech.com 10 Gigabit Fiber SFP+ Transceiver Module SM LC In Stock £208.89
Type: Modules
