Count on dependable, cost-efficient 10Gb Ethernet connections over multimode fiber with this Mini-GBIC module. This StarTech.com 10 Gigabit SFP+ is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the SFP-10G-LRM module, as well as other major brands of networking equipment.
It provides a dependable and cost-effective way to add, replace or upgrade the ports on your 10GBase-LRM networking equipment, backed by a lifetime warranty.
This 10 GbE SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The multimode SFP+ module is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco SFP-10G-LRM SFP transceiver. The StarTech.com SFP+ transceiver is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of 10 Gigabit networking devices.
Ideal for use in switches, routers and other networking equipment, the SFP+ provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The MM fiber transceiver module supports Digital Diagnostics Monitoring, a maximum distance of up to 220 m (722 ft.) and maximum data rates of up to 10Gbps.
You can count on SFP10GLRMST for reliable performance.
- Startech Cisco SFP-10G-LRM Compatible SFP+ Module, 10GBASE-LRM, 10GbE MMF Optic Transceiver, LC Connector, 200m, 1310nm, DDM, Cisco Firepower, ASR9000, C9300, Mini GBIC Transceiver - Lifetime Warranty (SFP10GLRMST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LRM
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 220 m
- OEM Manufacturer Equivalent Part Number
- Cisco SFP-10G-LRM
- 1.39 cm x 5.84 cm x 1.26 cm
- 25 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LRM
- 10GbE
- 10 Gbps
- 1310 nm
- 220 m
- Full duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
- IEEE 802.3ae
- 1 x Ethernet 10GBase-LRM - LC multi-mode x 2
- UL, FCC, RoHS, MSA
- Cisco SFP-10G-LRM
- 1.39 cm
- 5.84 cm
- 1.26 cm
- 25 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £18.69 |
StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m | In Stock | £35.41 |
StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £20.09 |
StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £33.25 |
StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £16.47 |
StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £24.53 |
StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £295.64 |
StarTech.com 10 Gigabit Fiber SFP+ Transceiver Module SM LC | In Stock | £208.89 |
