StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible
Quicklinx: CLVMWS00 Mfr#: 455883B21ST
Length: [N/A]
Colour: [N/A]
48 In Stock
£254.64 ex VAT
£305.56 inc VAT
Get dependable 10Gb Ethernet connections and cost-savings with this multi-mode Mini-GBIC module. This 10 Gigabit Ethernet SFP+ is HP compatible and engineered by StarTech.com to deliver what you need most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into HP BladeSystem c-Class equipment that supports the HP 455883-B21 module, as well as other major brands of networking equipment.
This 10GBase-SR SFP delivers 10 Gigabit connectivity up to 300 m (980 ft.) over multimode fiber cable. It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 10Gb SFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This 10 Gigabit multimode SFP+ is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP 455883-B21 SFP+ transceiver. The StarTech.com SFP+ transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of 10 Gigabit networking devices.
Ideal for use in HP BladeSystem c-Class and other compatible equipment, the SFP+ delivers reliable performance, allowing you to expand your network to remote segments cost-effectively. The multimode fiber transceiver module supports Digital Diagnostics Monitoring, a maximum distance of up to 300 m (980 ft.) and maximum data rates of up to 10Gbps.
StarTech.com HPE 455883-B21 Compatible SFP+ Module, 10GBASE-SR, 10GbE Multi Mode (MMF) Fiber Optic Transceiver, LC 300m, 850nm, DDM, HPE 6120XG, 6120G, Flex Fabric, Mini GBIC Transceiver - Lifetime Warranty (455883B21ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
10GbE
Max Transfer Distance
300 m
HP 455883-B21
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
300 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-SR - LC multi-mode x 2
MSA
HP 455883-B21
CLVM StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £21.20
CLVM StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £22.58
CLVM StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £37.56
CLVM StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £18.91
CLVM StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £28.29
CLVM StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £307.56
CLVM StarTech.com SFP - HP J4858C Comp. 10 Pack In Stock £247.21
CLVM StarTech.com SFP - HP J4859C Comp. 10 Pack In Stock £284.91
CLVM StarTech.com SFP - HP J4858C Compatible In Stock £37.48
CLVM StarTech.com Gb RJ45 SFP - HP Compatible In Stock £36.41
CLVM StarTech.com SFP+ - HP J9151A Compatible In Stock £168.21
CLVM StarTech.com SFP+ - HP JD092B Compatible In Stock £133.26
CLVM StarTech.com SFP - HP J4859C Compatible In Stock £44.53
CLVM StarTech.com Gb Copper SFP HP 453154-B21 Compatible In Stock £56.73
CLVM StarTech.com 10 Gb SFP+ HP 455883-B21 Compatible In Stock £254.64
CLVM StarTech.com HP JD089B Compatible SFP In Stock £39.71
Length: [N/A]
Colour: [N/A]
