Extend your VGA monitor connections by 10ft. This 10ft SVGA/VGA monitor extension cable lets you extend your VGA cable connection by 15ft.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 10ft Coax VGA Extension Cable (MXT101HQ10).
- StarTech.com 10 ft VGA Monitor Extension Cable - HD15 M/F - Supports resolutions up to 800x600 (MXT10110) - VGA extension cable - 3 m
- Length
- 3 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- HD-15 (VGA) - female
- RoHS
- Grey
- Limited lifetime warranty
- Designed For
- P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
- Length
- 3 m
- Grey
- Connector
- 15 pin HD D-Sub (HD-15) - male
- 15 pin HD D-Sub (HD-15) - female
- RoHS
- Designed For
