StarTech.com 10 ft VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 6BB3WS00 Mfr#: MXT10110
Length: 3m
Hurry, only 3 left in stock!
£4.17 ex VAT
£5.00 inc VAT
Extend your VGA monitor connections by 10ft. This 10ft SVGA/VGA monitor extension cable lets you extend your VGA cable connection by 15ft.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 10ft Coax VGA Extension Cable (MXT101HQ10).
StarTech.com 10 ft VGA Monitor Extension Cable - HD15 M/F - VGA extension cable - 3 m
VGA extension cable
Length
3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
RoHS
Grey
P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM
VGA extension cable
Length
3 m
Grey
Connector
15 pin HD D-Sub (HD-15) - female
RoHS
Length: 3m
Price Range Ex VAT: 0 - 50
