StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable
Quicklinx: 7RXRWS00 Mfr#: SVUSBVGA10
20 in stock
£9.75 ex VAT
£11.70 inc VAT
Connect VGA video and USB using a single thin KVM cable. The SVUSBVGA10 10-foot 2-in-1 USB KVM cable is specifically designed to work with any of our VGA USB KVM switches, helping to reduce tangles while maintaining excellent connectivity and performance.
To reduce clutter and optimize cable management efficiency, this professional grade USB KVM cable features an ultra-thin design that combines VGA and USB connectors into a single cable, making it ideal for connecting KVM switches inside a cabinet.
This high-performance 2-in-1 cable provides excellent video quality even for applications requiring high resolution performance.
StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable (SVUSBVGA10) - keyboard / video / mouse (KVM) cable - 3 m
Keyboard / video / mouse (KVM) cable
Colour-coded connectors
Length
3 m
Connectors
15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
Connectors (Second End)
P/N: SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV441DUSBI, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV831HD, SV841HDIE, SV841HDIEGB
Length
3 m
Connectors
RoHS
7RXR StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £396.55
7RXR StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £208.51
7RXR StarTech.com 4 Port USB VGA IP KVM Switch with Virtual Media In Stock £660.66
7RXR StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £446.11
7RXR StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £272.65
7RXR StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £465.66
7RXR StarTech.com 4 Port 1U Rackmount USB KVM Switch with OSD In Stock £147.05
7RXR StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £236.39
7RXR StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £257.93
7RXR StarTech.com 10 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £9.75
7RXR StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £6.73
Price Range Ex VAT: 0 - 50
