StarTech.com's professional line of 2-in-1 USB KVM switch cables are specifically designed to work with your StarView or Server Remote Control KVM switch, integrating the necessary USB and VGA connections into a single cable - reducing tangles while maintaining excellent performance. This 10ft 2-in-1 USB KVM switch cable features an ultra-thin design and is constructed of only high quality materials.
- StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable - VGA KVM Cable - USB KVM Cable - KVM Switch Cable (SVECONUS10) - video / USB cable - 3.05 m
- Video / USB cable
- Technology
- Coaxial
- Length
- 3.05 m
- Connectors
- 15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
- Connectors (Second End)
- Black
- Limited lifetime warranty
- Designed For
- P/N: CAB831HDU, CABCONS1716I, RACKCONS1908, RACKCONS1916, SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV565DUTPU, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV565UTPUL, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV841HDIE, SV841HDIEGB
- Video / USB cable
- Technology
- Coaxial
- Length
- 3.05 m
- Black
- Connectors
- PC 99
- Designed For
- P/N: CAB1631HD, CAB831HD, CAB831HDU, CABCONS1716I, RACKCONS1908, RACKCONS1916, SV1631DUSB, SV1631DUSBGB, SV1631DUSBU, SV1631DUSBUK, SV431DUSB, SV431DUSBU, SV565DUTPU, SV565UTP, SV565UTPU, SV565UTPUEU, SV565UTPUGB, SV565UTPUL, SV831DUSB, SV831DUSBA, SV831DUSBAU, SV831DUSBGB, SV831DUSBU, SV831DUSBUK, SV831HD, SV841HDIE, SV841HDIEGB
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £10.94 |
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £473.44 |
StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft | In Stock | £332.53 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £532.60 |
StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) | In Stock | £325.52 |
StarTech.com 8 Port USB KVM Switch Module for 1UCABCONS/17/19 | In Stock | £264.76 |
