StarTech.com 10 ft RP-SMA to RP-SMA Wireless Antenna Adapter Cable - M/F
Quicklinx: 4RXSWS00 Mfr#: RPSMA10MF
Type: Cable
Hurry, only 2 left in stock!
£9.11 ex VAT
£10.93 inc VAT
This 10ft RP-SMA to RP-SMA adapter Cable (M/F) lets you extend wireless antenna range without compromising on performance, by extending the cable length of any antenna or wireless device that uses a RP-SMA connector.
The RP-SMA/RP-SMA adapter features high quality construction that ensures flexibility without reducing performance, allowing wireless antenna installation anywhere it's needed.
StarTech.com RP-SMA to SMA Wireless Antenna Adapter Cable - Antenna cable - RP-SMA (M) to RP-SMA (F) - 10 ft - black - RPSMA10MF - antenna cable - 3 m
Cable
Antenna cable
Length
3 m
Connector
RP-SMA - male
Connector (Second End)
RP-SMA - female
Cable Type
Antenna cable
Length
3 m
Connector
RP-SMA - male
RP-SMA - female
Limited warranty - lifetime
Type: Cable
Price Range Ex VAT: 0 - 50
