This 10ft RP-SMA to RP-SMA adapter Cable (M/F) lets you extend wireless antenna range without compromising on performance, by extending the cable length of any antenna or wireless device that uses a RP-SMA connector.
The RP-SMA/RP-SMA adapter features high quality construction that ensures flexibility without reducing performance, allowing wireless antenna installation anywhere it's needed.
- StarTech.com RP-SMA to SMA Wireless Antenna Adapter Cable - Antenna cable - RP-SMA (M) to RP-SMA (F) - 10 ft - black - RPSMA10MF - antenna cable - 3 m
- Cable
- Antenna cable
- Length
- 3 m
- Black
- Connector
- RP-SMA - male
- Connector (Second End)
- RP-SMA - female
- Limited lifetime warranty
- Cable Type
- Antenna cable
- Length
- 3 m
- Black
- Connector
- RP-SMA - male
- RP-SMA - female
- Limited warranty - lifetime
