Connect a Mini DisplayPort-equipped PC or Mac to a VGA monitor/projector, with a 10ft long white cable. The MDP2VGAMM10W 10ft active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped device (Desktop PC, Mac, Laptop, Ultrabook, etc.) directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your Mini DisplayPort computer to work with a VGA monitor or projector. The cable features a stylish white design, that is well-suited for connecting Mac computers.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
- StarTech.com 10ft Mini DisplayPort to VGA Adapter Cable mDP to VGA - White - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
- Active cable (signal regeneration), Thunderbolt port compatible
- Cables Included
- 1 - 3 cm
- Plug and Play, FCC, RoHS, WEEE, RCM
- 153 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 40 - 85%
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £20.08 |
StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £18.62 |
StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White | In Stock | £18.39 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White | In Stock | £21.45 |
StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £23.60 |
StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £22.05 |
StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White | In Stock | £22.05 |
