StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black
Quicklinx: 920HWS00 Mfr#: MDP2VGAMM10B
Connect a Mini DisplayPort-equipped PC or Mac to a VGA monitor/projector, with a 10ft long black cable. The MDP2VGAMM10B 10ft active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped device (Desktop PC, Mac, Laptop, Ultrabook, etc.) directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your Mini DisplayPort computer to work with a VGA monitor or projector.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 10 ft Mini DisplayPort to VGA Adapter Cable - mDP to VGA Video Converter - Mini DP to VGA Cable for Mac/PC 1920x1200 - Black (MDP2VGAMM10B) - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
Active cable (signal regeneration), Thunderbolt port compatible
1 - 3 m
FCC, RoHS, WEEE
90 g
Enclosure Colour
Limited warranty - 3 years
60 °C
40 - 85%
920H StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £14.70
920H StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White In Stock £5.38
920H StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £19.69
920H StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £18.75
920H StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £20.72
920H StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £21.05
920H StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £6.99
920H StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 In Stock £15.03
