StarTech.com 10 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
Quicklinx: 76MNWS00 Mfr#: MDP2DPMM10
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM10 10ft Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
  • High-quality connectivity
    This 10 ft Mini DisplayPort to DisplayPort cable offers a direct connection between your mDP and DP compatible devices, ensuring reliable signal transmission without the need for adapters.
  • Robust design
    Featuring a nickel-plated connector and a durable 32 AWG wire, this cable is designed to withstand frequent plugging and unplugging while maintaining signal integrity.
  • Versatile compatibility
    Designed to support Thunderbolt and DisplayPort 1.2 with HBR2, this cable is compatible with a wide range of devices, making it a versatile solution for connecting your PC to a display.
StarTech.com 10ft Mini DisplayPort to DisplayPort Cable - M/M - mDP to DP 1.2 Adapter Cable - Thunderbolt to DP w/ HBR2 Support (MDP2DPMM10) - DisplayPort cable - 3 m
DisplayPort cable
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
P/N: BOX4HDECP, CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP, DPBOOST, HD2DP, MDPEXT3, SP123DP, SV431DPDDUA2, SV431DPUA2
DisplayPort cable
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Length
3 m
Connector
20 pin DisplayPort - male
RoHS
76MN StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.24
76MN StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £8.54
76MN StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £3.73
76MN StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £14.18
76MN StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £19.68
76MN StarTech.com USB 3.0 to 4K DisplayPort External Multi Monitor Video Graphics Adapter In Stock £64.38
