StarTech.com 10 ft Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable
Quicklinx: 76N0WS00 Mfr#: N6PATCH10GR
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATCH10GR Cat 6 Patch Cable (10 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
  • 100% Copper - a better value
    StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable based on a copper-coated aluminum core, we make no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG Wire
    This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because we use a high quality copper wire, our cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron Gold Connectors
    This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 10ft CAT6 Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Cat 6 Patch Cord, 10GbE UTP CAT6 Network Cable, Gray CAT6 Ethernet Cable, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATCH10GR) - patch cable - 3 m - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
P/N: US1GC30A
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded, snagless
Length
3 m
Grey
Connector
RJ-45 - male
RJ-45 - male
UL, RoHS, ETL - up to 650 MHz
P/N: US1GC30A
