Product
StarTech.com 10 ft DVI-D Dual Link Cable - M/M
Quicklinx: 3ZL9WS00 Mfr#: DVIDDMM10
Type: DVI
Length: 3m
19 in stock
£10.60 ex VAT
£12.72 inc VAT
Standard delivery Delivered within 3-5 working days
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM10 10ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 10 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com 10 ft DVI-D Dual Link Cable - M/M - DVI cable - 3 m
DVI cable - dual link
Length
3 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: RKCONS2001GB, USB2DVIPRO, RACKCONS2001, DP2DVID, SV431DVIDGB, DVI2HDMI, USB2DVIE, HDMI2DVI, SV431DVIDDU, SV431DDUSB, SV231DDUSB, USB2DVI, VID2DVIDTVGB, VGA2DVIIGB, VGA2DVII, VID2DVIDTV, SV421DVIDD, SV221DVIDD, SV221DVI
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
3 m
Connector
24+1 pin digital DVI - male
StarTech.com 2 Port DVI PS/2 KVM Switch, 4 Port DVI Dual Monitor KVM Switch with PS/2, Composite and S-Video to DVI-D Video Converter with Scaler, DisplayPort to DVI Dual Link Active Converter – USB Powered, DVI and Digital Audio to HDMI Converter, HDMI to DVI-D Video Converter with Audio, High Res RackMount LCD Console for 19" Rack, Professional USB to DVI External Dual or Multi Monitor Video Adapter, USB DVI External Dual or Multi Monitor Video Adapter, USB DVI VGA External Dual or Multi Monitor Video Adapter, VGA to DVI-I Video Converter with Scaler , StarTech.com Converge A/V HDMI to DVI-D with SPDIF Audio Converter
3ZL9 StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.62
3ZL9 StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £12.91
3ZL9 StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
Type: DVI
Length: 3m
Price Range Ex VAT: 0 - 50
