StarTech.com 10 ft DVI-D Dual Link Cable - M/M
Quicklinx: 3ZL9WS00 Mfr#: DVIDDMM10
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM10 10ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 10 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com Dual Link DVI Cable - 10 ft - Male to Male - 2560x1600 - DVI-D Cable - Computer Monitor Cable - DVI Cord - Video Cable (DVIDDMM10) - DVI cable - 3 m
DVI cable - dual link
Length
3 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DK30BACDD, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, HD2DPVGADVI, MDP2DVID2, MST30C2HHPD, MST30C2HHPDU, RKCOND17HD, SV431DL2DU3A
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
3 m
Connector
24+1 pin digital DVI - male
P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DK30BACDD, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2DVI, DP2DVI2, DP2DVID2, DP2DVIS, DP2VGDVHD, DVI92030202L, DVIDDMM15, DVIEXTAA6IN, DVISPL1DD, HD2DPVGADVI, HDDVIMF8IN, HDMIDVIMF, MDP2DPDVHD, MDP2DVI, MDP2DVI3, MDP2DVID2, MDP2DVIS, MDP2DVIW, MST30C2HHPD, MST30C2HHPDU, RKCOND17HD, SV221DVIDD, SV231DD2DUA, SV231DDUSB, SV231DDVDUA, SV231DVIDDU, SV231DVIUAHR, SV231DVIUDDM, SV231QDVIUA, SV231TDVIUA, SV431DD2DUA, SV431DDUSB, SV431DDVDUA, SV431DL2DU3A, SV431DVIDDU, SV431DVIUAQV, SV431DVIUDDM, SV431TDVIUA, SV831DVIU, USB2DVIE3, USB2DVIPRO2, USB32DVIEH, USB32DVIPRO, USB32HDDVII, USB3SDOCKDD, USB3SDOCKHDV, VSEDIDDVI
3ZL9 StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 In Stock £66.16
3ZL9 StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 In Stock £65.01
