StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 76RNWS00 Mfr#: DISPLPORT10L
Type: Video
Length: 3m
More than 50 in stock
£13.88 ex VAT
£16.65 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices. The DISPLPORT10L 10ft DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches - 4K x 2K (4096 x 2160) @ 60Hz - DPCP & HDCP - Male to Male DP Video Monitor Cable (DISPLPORT10L) - DisplayPort cable - 3 m
DisplayPort cable
Shielded
Latched
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
P/N: BOX4HDECP2, CDP2DP14B, CDP2DPVGA, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CHDDPPD, DK31C3HDPD, DK31C3HDPDUE, DVI2DP2, MOD4AVHD, MOD4AVHDBT, MST14DP123DP, ST121HDBTSC, SV211DPUA4K, SV231DPU34K, SV431DPDDUA2, SV431DPUA2, TB32DP14, USB32DP24K60, USB32DPES2
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched
Length
3 m
Connector
20 pin DisplayPort - male
P/N: BOX4CABLE, BOX4HDECP2, CDP2DP, CDP2DP14B, CDP2DPUCP, CDP2DPVGA, CDP2DPW, DK30A2DH, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK30CH2DPPD, DK30CHDDPPD, DK31C3HDPD, DK31C3HDPDUE, DPBOOST, DPPNLFM3, DPPNLFM3PW, DVI2DP2, GCMDP2DPMF, HD2DP, HD2DPVGADVI, HDMI2DP, HDVGADP2HD, MDP2DPDVHD, MDP2DPMF6IN, MOD4AVHD, MOD4AVHDBT, MST14DP123DP, MST30C2DPPD, MST30C2HDPPD, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, SP123DP, ST121HDBTSC, STDHVHDBT, SV211DPUA, SV211DPUA4K, SV231DPDDUA, SV231DPDDUA2, SV231DPU, SV231DPU34K, SV231DPUA, SV431DPDDUA2, SV431DPU3A2, SV431DPUA, SV431DPUA2, TB2DOCK4K2DP, TB32DP14, TB32DP2, TB32DP2T, USB32DP24K60, USB32DP4K, USB32DPES2, USB32DPPRO, USB3DDOCKFT, USB3DOCKH2DP, USB3DOCKHDPC
Type: Video
Length: 3m
Stock Status: In stock
