StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
Quicklinx: 76RNWS00 Mfr#: DISPLPORT10L
Type: Video
Length: 3m
More than 50 in stock
£13.69 ex VAT
£16.42 inc VAT
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices. The DISPLPORT10L 10ft DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
StarTech.com 10 ft Certified DisplayPort 1.2 Cable M/M with Latches DP 4k - DisplayPort cable - 3 m
DisplayPort cable
Shielded
Latched
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
P/N: SV231DPUA, VS421DP, SV231DPDDUA, SV431DPUA, SV231DPU
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched
Length
3 m
Connector
20 pin DisplayPort - male
StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control
Type: Video
Length: 3m
Price Range Ex VAT: 0 - 50
