StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M
Quicklinx: 3ZMMWS00 Mfr#: SCNM925FM
Length: 3m
£3.88 ex VAT
£4.65 inc VAT
Connect your serial devices, and transfer your files. The SCNM925FM 10ft Cross Wired Serial/Null Modem Cable features one DB9 female and one DB25 male connector, allowing you to connect a 9-pin serial device to a 25-pin serial port, or transfer files from PC-to-PC via a serial connection.
StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M - Null modem cable - DB-9 (F) to DB-25 (M) - 10 ft - SCNM925FM - null modem cable - DB-9 to DB-25 - 3 m
Null modem cable
Length
3 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
25 pin D-Sub (DB-25) - male
P/N: EC1S232U2, ICUSB23208FD, ICUSB23216FD, ICUSB2321FIS, ICUSB2322F, ICUSB2322I, ICUSB232INT1, ICUSB232INT2, ICUSB232IS, ICUSB232PROC, ICUSB232SM3, PCI2S232485I, PCI2S4851050, PCI4S954PW, PEX1S553LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S953, PEX2S953LP, PEX4S553, PEX4S553B
Null modem cable
Length
3 m
Connector
P/N: 10PKPCI1S550, EC1S232U2, EC1S952, EC2S952, IC485S, ICUSB232, ICUSB23208FD, ICUSB23216FD, ICUSB2321FIS, ICUSB2321X, ICUSB2322F, ICUSB2322I, ICUSB2322X, ICUSB2324X, ICUSB2328, ICUSB232DB25, ICUSB232INT1, ICUSB232INT2, ICUSB232IS, ICUSB232PROC, ICUSB232SM3, ICUSB422IS, PCI1S550, PCI2S1P, PCI2S232485I, PCI2S4851050, PCI2S550, PCI2S550_LP, PCI2S950, PCI4S550, PCI4S550N, PCI4S954PW, PEX1S553LP, PEX1S952LP, PEX1S953LP, PEX2S1050, PEX2S1P553B, PEX2S553, PEX2S553LP, PEX2S953, PEX2S953LP, PEX4S553, PEX4S553B, PEX4S952, PEX8S950LP
Length: 3m
