Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high level of performance and is an excellent choice for Power over Ethernet (PoE) applications. Plus, Cat 6a cables are backward-compatible with Cat5e and Cat6 cables, ensuring versatile network connection options. All of the Cat 6a cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that the Cat 6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
- StarTech.com 10 ft CAT6a Ethernet Cable - 10 Gigabit Category 6a Shielded Snagless RJ45 100W PoE Patch Cord - 10GbE Blue UL/TIA Certified - patch cable - 3.05 m - blue
- Patch cable - CAT 6a
- Technology
- Shielded twisted pair (STP)
- Wiring Scheme
- T568B
- Shielding Material
- Aluminium-polyester foil
- Molded
- Length
- 3.05 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Designed For
- P/N: BNDTB10GI, SFP10GBTST, ST10000SPEXI, ST10GPEXNDPI, ST10GSPEXNB, ST20000SPEXI, ST5GPEXNB
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Molded
- Length
- 3.05 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- UL 444, RoHS - up to 500 MHz
- Designed For
