Connect VGA and USB-equipped computers to a KVM Switch using a single cable. The SVUSB2N1 10 10ft 2-in-1 USB + VGA KVM switch Cable is constructed of high quality materials and is expertly designed to ensure crystal clear display quality, and reliable connections.
The universal USB KVM switch cables prevent tangles and keep your workspace neat, while delivering excellent performance with your StarTech.com or other KVM switch.
- StarTech.com 10 ft 2-in-1 Universal USB KVM Cable - 10ft VGA KVM Cable - 10ft USB KVM Cable - 10ft KVM Switch Cable (SVUSB2N1_10) - video / USB cable - 3 m
- Video / USB cable
- Length
- 3 m
- Connectors
- 4 pin USB Type B - male , 15 pin HD D-Sub (HD-15) - female
- Connectors (Second End)
- 4 pin USB Type A - male , 15 pin HD D-Sub (HD-15) - male
- Limited lifetime warranty
- Designed For
- P/N: RKCOND17HD, SV231USBGB, SV231USBLC, SV431, SV431H, SV431USB, SV431USBAE, SV431USBAEGB, SV431USBDDM
- Video / USB cable
- Length
- 3 m
- Connectors
- 4 pin USB Type A - male ¦ 15 pin HD D-Sub (HD-15) - male
- Designed For
StarTech.com 6 ft 2-in-1 USB KVM Cable | In Stock | £7.05 |
StarTech.com 10 ft 2-in-1 Universal USB KVM Cable | In Stock | £11.48 |
StarTech.com 2 Port Professional USB KVM Switch Kit with Cables | In Stock | £64.06 |
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £86.26 |
StarTech.com 4 Port Rack Mountable USB KVM Switch with Audio & USB Hub | In Stock | £94.34 |
StarTech.com 15 ft 2-in-1 Universal USB KVM Cable | In Stock | £15.36 |
