StarTech.com 10 ft 14 AWG Computer Power Cord Extension - C14 to C13
Quicklinx: 7WZ5WS00 Mfr#: PXT1001410
Select:
  • 3m
Extend a High-Power Power Cord Connection by up to 10ft. The PXT1001410 Power Cord Extension Cable's heavy-duty (14 AWG) wire gauge is more than sufficient for handling higher power loads, making it a reliable solution for connecting larger servers to PDUs (Power Distribution Units).
This 10-foot Power Extension Cable features one computer power female connector and one hooded male power connector, enabling you to extend the connection between your PC and monitor by up to 10ft.
StarTech.com 10ft (3m) Heavy Duty Extension Cord, IEC C14 to IEC C13 Black Extension Cord, 15A 125V, 14AWG, Heavy Gauge Power Extension Cable, IEC C14 to IEC C13 AC Power Cord - UL Listed - power extension cable - IEC 60320 C14 to power IEC 60320 C13 - 3 m
Power extension cable
Length
3 m
Connector
Power IEC 60320 C14
Connector (Second End)
Power IEC 60320 C13
Rated Voltage
AC 110 V
P/N: RKCOND17HD
American Wire Gauge (AWG)
14
Rated Voltage
AC 110 V
Length
3 m
Connector
Power IEC 60320 C14
Power IEC 60320 C13
RoHS
P/N: RKCOND17HD
