Rack Mount Cage Nuts and Screws 10-32 Black. Versatile Mounting Options
This 50-pack of 10-32 cage nuts and screws are perfect to have on hand for installing rack mount hardware, such as your server, network or audio/video equipment. The design of the captive nuts makes for easy slide-on installation. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act, allowing government GSA Schedule purchases.
The bulk pack is also suitable for new server rack and cabinet setups - perfect for those times when you drop or misplace a nut or screw. The bulk package ensures that you have enough cage nuts and screws available for all of your square hole rack installations when you need them.
Durable Design
The steel server rack screws and cage nuts come in an all-black finish for a seamless look.
CABSCREW1032 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
- Startech 50 Pack 10-32 Server Rack Cage Nuts and Screws with Washers, Rack Mount Hardware Kit, Network/IT Equipment Cabinet Clip/Captive Nuts & Bolts for Square Rack Holes, Black, TAA - 50-Pk 10-32 Cage Nuts (CABSCREW1032) - rack screws and nuts - TAA Compliant
- Product Type
- Rack screws and nuts
- Packaged Quantity
- 50 (specifications are for single item)
- Package Content
- 50 screws (10-32), 50 cage nuts (10-32)
- Black
- Product Material
- Steel
- 1.2 cm
- 502 g
- Pricing Type
- Government GSA, federal government
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: 2POSTRACK, 4POSTRACK12, 4POSTRACK25, 4POSTRACK36, 4POSTRACKBK, 4POSTRACKHD, ADJSHELF, CAB1019WALL, RK1219WALH, RK1219WALHM, RK1219WALHMR, RK1219WALHR, RK1219WALL, RK1219WALLMR, RK1219WALLR, RK12OD, RK2236BKF, RK2236BKFR, RK4236BK, RK4236BKNS, RK4242BK, RK4242BKNS, RK812WALLO, RKLCDBK, SH39LK
- Packaged Quantity
- Product Type
- Product Material
- Steel
- Package Content
- 1.2 cm
- Diameter
- 0.48 cm
- 502 g
- Shipping Dimensions (WxDxH) / Weight
- 22 cm x 12 cm x 1.6 cm / 507 g
- Black
- RoHS, REACH
- Pricing Type
- TAA Compliant
- Limited warranty: - 2 years
- Designed For
- P/N: 2636CABINET, 2POSTRACK, 4POSTRACK12, 4POSTRACK25, 4POSTRACK36, 4POSTRACKBK, 4POSTRACKHD, 4UDRAWER, 7236CABINET, ADJSHELF, CAB1019WALL, CABSHELF, CABSHELFD, RK1219WALH, RK1219WALHM, RK1219WALHMR, RK1219WALHR, RK1219WALL, RK1219WALLMR, RK1219WALLR, RK12OD, RK2236BKF, RK2236BKFR, RK4236BK, RK4236BKNS, RK4242BK, RK4242BKNS, RK812WALLO, RKLCDBK, SH39LK
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £94.63 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £41.63 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £68.51 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £45.84 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.71 |
StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £102.81 |
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters | In Stock | £514.25 |
