Extend your 10/100Mbps network by up to 1km over Ethernet or RJ11 phone lines.
The 110VDSLEXTGB VDSL Ethernet extender kit allows you to span a 10/100 network over extremely long distances (up to 1km) while still maintaining high-speed network connectivity.
The device allows you to run the connection over standard RJ45 cabling, existing RJ11 phone lines, or any other set of single pair wires.
The VDSL (VDSL2) kit is simple to install and provides an out-of-the-box solution as both the Ethernet-VDSL extender and receiver units are included. A perfect solution for a broad range of applications including connecting isolated user stations within the same building or between separate buildings, or overcoming infrastructure obstacles and distances (e.g. older stone/concrete architecture) where new wiring or wireless may be impossible.
The VDSL Ethernet LAN Extender kit helps to eliminate expense by allowing video streaming and data to share the same telephone pair without interference.
The 110VDSLEXT requires only a single pair of wires to function, while offering the ability to use multiple sets of the devices to create several simultaneous connections to your remote building. In these multiple set configurations, you have the ability to use up to 4 sets over a single Cat5e or Cat6 cable which can be used as separate LAN (or VLAN) connections, or bridged into a trunk line for additional speed/bandwidth over long distances (up to two sets only over standard Cat5).
Package includes - 1 Extender, 1 Receiver, 2 RJ45 to VSDL cable, 2 Power Supply Units, 1 Instruction Manual
Extended connectivity
Experience seamless network integration with the StarTech.com Ethernet Extender Kit, enabling Ethernet 10Base-T/100Base-TX connections over a single pair wire for distances up to 1 km. This feature ensures reliable connectivity even in challenging physical environments, making it ideal for extending network coverage to remote areas of a building or across campus. -
Robust performance
Designed to operate under a wide range of environmental conditions, the Ethernet Extender Kit boasts an operating humidity range of 5 - 95% and temperature tolerance from 0°C to 50°C. This resilience ensures consistent performance and reliability in various climates and settings. -
High compatibility
With support for IEEE 802.3, IEEE 802.3u, and IEEE 802.3x standards, the Ethernet Extender Kit offers broad compatibility with existing networking equipment. This ensures a smooth and hassle-free integration into your current network infrastructure, providing a cost-effective solution for network expansion. -
Advanced features
The Ethernet Extender Kit comes equipped with auto-negotiation, auto-uplink (auto MDI/MDI-X), flow control, and full duplex capability. These features optimize network performance, enhance data transmission efficiency, and ensure a stable and reliable network connection for all connected devices. -
Environmentally conscious
Compliance with FCC and RoHS standards reflects StarTech.com's commitment to environmental responsibility. By choosing this Ethernet Extender Kit, you're not only selecting a high-quality networking solution but also supporting eco-friendly business practices.
- StarTech.com 10/100 VDSL2 Ethernet Extender Kit over Single Pair Wire - short-haul modem - 10Mb LAN, 100Mb LAN, Ethernet over VDSL
- Short-haul modem
- Form Factor
- External
- Localisation
- United Kingdom
- Cabling Type
- 10Base-T, 100Base-TX
- Data Link Protocol
- Max Transfer Distance
- 1 km
- 7.2 cm x 9.5 cm x 2.2 cm
- 90 g
- 2-year warranty
- Short-haul modem
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Cabling Type
- 1 km
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x
- 1 x Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x modem - VDSL2 - RJ-45
- FCC, RoHS
- Power Device
- External power adapter
- 7.2 cm
- 9.5 cm
- 2.2 cm
- 90 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 95%
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.76 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
