The POESPLT100 10/100 Mbps PoE Power over Ethernet Splitter with 5-12V Output separates the data and power connections received from your Power Sourcing Equipment(PSE) such as a single port PoE injector or a PoE Switch.
At the remote end of your PoE connection, the POESPLT100 gives you a standard DC jack with selectable 5, 7.5, 9 or 12V output and separate Ethernet data connection allowing you to take advantage of power of Ethernet infrastructure, and use a variety of peripherals in places where no wall outlet exists.
- StarTech.com 10/100 PoE Power over Ethernet Splitter 5V/12V - PoE splitter - 19.2 Watt
- PoE splitter - external
- 240 g
- Output Voltage
- 5 / 7.5 / 9 / 12 V
- Power Capacity
- 19.2 Watt
- Output connectors
- 1 x RJ-45
- Silver
- 7.5 cm x 10.2 cm x 2.2 cm
- 2-year warranty
- Designed For
- P/N: IES8100POE, POEEXT1GAT, POEEXT2GAT, POEINJ4G, UPOESPLT1G
- Silver
- Power Output Connectors Details
- 1 x RJ-45
- Output Voltage
- Power Capacity
- 19.2 Watt
- FCC, RoHS
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- 7.5 cm
- 10.2 cm
- 2.2 cm
- 240 g
- Designed For
StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable | In Stock | £384.67 |
