StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST 2 km
Quicklinx: 85DDWS00 Mfr#: ET90110ST2
Hurry, only 3 left in stock!
£68.63 ex VAT
£82.35 inc VAT
Convert and extend a 10/100 Mbps Ethernet connection up to 1.2 miles/2km over Multi Mode ST fiber. The ET90110ST2 10/100 Mbps Multimode Fiber Media Converter (ST, 2 km) lets you extend a Fast Ethernet network (10/100 Mbps) over multimode fiber, at distances of up to 2 km (1.2 miles).
A cost-effective solution for connecting a 10/100 Mbps Ethernet (10/100Base-T) network to remote network segments over a 100Base-FX fiber backbone. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to ST Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
StarTech.com 10/100 Mbps Ethernet to Fiber Optic Media Converter - Steel - Chassis Mount - ST Multimode - 1310nm - 2km (ET90110ST2) - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / ST multi-mode
External
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
2 km
AC 120/230 V
9.5 cm x 16 cm x 2 cm
0.6 kg
P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
External
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - ST multi-mode female x 2
FCC, RoHS
External power adapter
AC 120/230 V
9.5 cm
16 cm
2 cm
0.6 kg
60 °C
10 - 90%
85DD StarTech.com 10/100 Mbps Multi Mode Fiber Media Converter ST 2 km In Stock £68.63
85DD StarTech.com DC Power Adapter - 12V, 2A In Stock £11.71
85DD StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
Type: Media Converter
