StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km
Quicklinx: 6BDBWS00 Mfr#: MCM110SC2GB
Hurry, only 3 left in stock!
£38.66 ex VAT
£46.39 inc VAT
Convert and extend a 10/100 Mbps Ethernet connection up to 2 km over Multi Mode SC fiber.
The MCM110SC2GB 10/100 Multi Mode Fiber Ethernet Media Converter SC 2 km creates an economical, cost-effective Ethernet-fiber link, transparently converting to/from 10Base-T or 100Base-Tx Ethernet signals and 100Base-Fx optical signals to extend an Ethernet network connection over an SC terminated multimode fiber backbone.
The converter supports a maximum multimode fiber optic cable distance of 2 kilometers (1.2 miles), providing a simple solution for connecting 10Base-T/100Base-Tx Ethernet networks to remote locations using SC-terminated multimode fiber, while delivering solid network performance and scalability.
This versatile GbE Ethernet to Fiber converter is compatible with most 3COM, Cisco, Lucent and Nortel networks and fully complies with applicable IEEE 802.3 standards.
StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / SC multi-mode
External
United Kingdom
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
2 km
AC 230V
7.3 cm x 9.7 cm x 2.3 cm
90 g
External
United Kingdom
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Status Indicators
Port transmission speed, port duplex mode, power, link/activity
Flow control, MDI/MDI-X switch, auto-negotiation, half duplex mode, full duplex mode, Link Fault Pass Through function (LFP), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - SC multi-mode female x 2
FCC, RoHS
External power adapter
AC 230V
7.3 cm
9.7 cm
2.3 cm
90 g
50 °C
0 - 90%
6BDB StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km In Stock £38.66
6BDB StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
Type: Media Converter
