StarTech.com 10/100/1000 Mbps Gigabit 1 Port USB over IP Device Server
Quicklinx: 7P3MWS00 Mfr#: USB1000IP
Connect and share a high-speed USB 2.0 peripheral over a gigabit network. The USB1000IP 10/100/1000 Mbps Gigabit 1-Port USB over IP Device Server provides a simple and convenient way to extend and share a USB device over long distances, for multiple users connected to your Ethernet network. This flexible device auto-detects Ethernet network link speed and can connect through a network hub/switch/router, or directly to a PC, making it perfect for connecting and sharing devices such as mass storage, card readers, digital cameras, webcams, printers (including multi-function), fax, scanners or serial adapters with multiple users. Unlike slower 10/100 devices, gigabit speeds allow attached USB 2.0 devices to function at full speeds as if they were locally connected. The USB over IP Device server includes bundled software that provides a simple interface to view the status of, and connect to the detected device over the LAN, and features the option to automatically connect to your device after a reboot.
StarTech.com 10/100/1000 Mbps Gigabit 1 Port USB 2.0 over IP Device Server Adapter, USB Ethernet Over LAN Network Printer Converter - Windows 7 / XP / Vista ONLY - device server
Device server
External
Ethernet, Fast Ethernet, Gigabit Ethernet, USB 2.0
Microsoft Windows Vista / XP / 7
AC 120/230 V
3.8 cm x 7.7 cm x 2.3 cm
35 g
Device server
3.8 cm
7.7 cm
2.3 cm
35 g
Enclosure Colour
External
Wired
Status Indicators
Link/activity
IEEE 802.3
1 x USB 2.0 - Type A , 1 x 1000Base-T - RJ-45
External power adapter
AC 120/230 V
5 °C
50 °C
20 - 80%
7P3M StarTech.com 4-to-4 USB 3.0 Peripheral Sharing Switch In Stock £75.42
