StarTech.com 10' DP to VGA Cable with Audio
Quicklinx: BM09WS00 Mfr#: DP2VGAAMM3M
Connect the audio and video from your DisplayPort PC directly to a monitor. Now you can organize your workspace with less mess than ever before.
This unique 10-foot DisplayPort to VGA adapter cable features a built-in audio port, which enables you to connect a VGA monitor as well as speakers to your DisplayPort (DP) equipped desktop computer.
Remove the cable clutter from your desk. With the built-in audio port you no longer need to run a separate audio cable from your monitor or speakers directly to your desktop or laptop computer. Simply plug the audio cable from your speakers into the adapter cable for a simple and tidy solution.
In order to use the audio function of the adapter, it needs to be powered through USB. Simply connect a Micro-USB cable into the adapter from your computer, monitor or USB grommet in order to provide the necessary power.
The adapter guarantees you always have all of the connections you need. If the audio port on your computer is damaged or blocked, this adapter cable ensures you still have sound available for watching video presentations, listening to music while you work or chatting with your colleagues over Skype.
StarTech.com 10 ft / 3m DisplayPort to VGA Adapter Cable with Audio - DisplayPort adapter - 3 m
DisplayPort adapter
Length
3 m
Connectors
DisplayPort - male
Connectors (Second End)
15 pin D-Sub (DB-15) - male , Mini-phone stereo 3.5 mm - female , Micro-USB Type B (power only) - female
FCC, RoHS
3-year warranty
P/N: DK30CH2DEP, DK30CH2DEPUE
DisplayPort adapter
Length
3 m
Connectors
20 pin DisplayPort - male
15 pin D-Sub (DB-15) - male , Mini-phone stereo 3.5 mm - female , 5 pin Micro-USB Type B (power only) - female
FCC, RoHS
3-year warranty
BM09 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.94
BM09 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.60
BM09 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
BM09 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
BM09 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
BM09 StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.94
BM09 StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.46
BM09 StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £14.91
BM09 StarTech.com DP to VGA Adapter with Audio In Stock £19.30
BM09 StarTech.com DisplayPort to VGA Adapter - 1920x1200 In Stock £63.99
