StarTech.com 10' Cat5e Patch Cable Black
Quicklinx: 400GWS00 Mfr#: M45PATCH10BK
Length: 3m
Colour: Black
41 in stock
£3.31 ex VAT
£3.97 inc VAT
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PATCH10BK Cat5e Patch Cable (10 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable black PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
This Cat5e Patch Cord delivers reliable performance and is constructed of only top quality materials.
StarTech.com Cat5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, the cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This molded patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • 100% copper - a better value
  • 24 AWG wire
    This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
StarTech.com Cat5e Ethernet Cable - 10 ft - Black - Patch Cable - Molded Cat5e Cable - Network Cable - Ethernet Cord - Cat 5e Cable - 10ft (M45PATCH10BK) - patch cable - 3 m - black
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
P/N: ST1000SPEX4, SV431USBAN, SV231USBAN
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
3 m
Connector
RJ-45 - male
RJ-45 - male
UL
StarTech.com 2 Port USB KVM Switch with Network Hub and Audio, 4 Port USB KVM Switch with Ethernet Switch and Audio & USB Hub
Length: 3m
Colour: Black
Price Range Ex VAT: 0 - 50
