Add serial communication support to your desktop computer or Small Form Factor (SFF) system, using this serial card. RS-232 (DB9) support enables control and communication with a serial peripheral device.
Legacy Connectivity
Install this card to enable the continued use of legacy serial devices, preventing down time and avoiding costly upgrades. The PCIe serial card is ideal for system upgrades in a wide range of applications for logistics, manufacturing, and freight sectors, and the IT industry, such as POS equipment, security systems, A/V installations, and more. -
Connect with Ease
The RS-232 card features 16C1050 UART support, 256-byte FIFO (transmit/receive), bi-directional speeds up to 921.6 Kbps, low-profile bracket is included for SFF systems, and serial port LED status lights. In addition, it supports Windows and Linux systems for maximum compatibility. 11050-PC-SERIAL-CARD is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com PCI Express Serial Card, PCIe to RS232 (DB9) Serial Interface Card, PC Serial Card with 16C1050 UART, Standard or Low Profile Brackets, COM Retention, For Windows & Linux - PCIe to DB9 Card (11050-PC-SERIAL-CARD) - serial adapter - PCIe 2.0 - RS-232 x 1
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x1
- PCI Specification Revision
- PCIe 2.0
- Ports
- RS-232 x 1
- 1.8 cm x 6.5 cm x 6.7 cm
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- 16C1050 UART
- Yellow
- System Requirements
- Linux, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows 7 / 8 / 10 / 11
- 2-year warranty
- Serial adapter
- Form Factor
- PCIe 2.0
- Ports
- RS-232 x 1
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- Status Indicators
- Status
- 256-byte FIFO
- 16C1050 UART
- 1 x RS-232 - 9 pin D-Sub (DB-9) - male (external)
- Included Accessories
- Low-profile bracket
- Yellow
- OS Required
- 1.8 cm
- 6.5 cm
- 6.7 cm
- Shipping Width
- 20.7 cm
- Shipping Depth
- 14.4 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 200 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
