The PM1115UWGB Wireless-N Print Server lets you share a standard USB printer with multiple users simultaneously over a Wi-Fi network, or a wired LAN connection.
This compact wireless print server supports 802.11 b/g/n wireless standards for functionality with almost any wireless network, plus, serving as a primary or backup interface the print server also offers an RJ45 port for 10/100 Mbps wired connections. Providing wireless network printing access enables you to place your printer in any location with network access and avoids the added cost of purchasing individual printers for each workstation or area.
This wireless USB print server can have you up and running in minutes, using either a web-based interface or a Windows based installation wizard, and also features a Wi-Fi Protected Setup (WPS) button for quick and easy connection to your wireless network. Compatibility with USB 2.0 standards and a wide variety of USB printers and operating systems makes this network print server perfect for installation into mixed environments, with simple network management protocol (SNMP) support for remote monitoring.
- StarTech.com 1-Port Wireless N USB 2.0 Network Print Server - 10/100 Mbps Ethernet USB Printer Server Adapter - Windows 10 - 802.11 b/g/n (PM1115UW) - print server - USB 2.0 - 10/100 Ethernet x 1
- Print server
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- 5.8 cm x 7.2 cm x 2.5 cm
- 65 g
- Localisation
- United Kingdom
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 802.11b/g/n
- TCP/IP, AppleTalk, NetBEUI/NetBIOS, IP/IPX, SMB
- Frequency Band
- 2.4 GHz
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0, IEEE 802.11n
- White
- Power
- AC 120/230 V
- System Requirements
- Apple MacOS 9.x, Apple MacOS X 10.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.4.x LTS versions, Microsoft Windows Server 2019
- 2-year warranty
- Print server
- Form Factor
- External
- USB 2.0
- Localisation
- United Kingdom
- Ports
- Connectivity Technology
- Wireless, wired
- Cabling Type
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- SNMP
- Frequency Band
- 2.4 GHz
- Status Indicators
- Status, WLAN, USB
- Wi-Fi Protected Setup (WPS)
- 1 x 100Base-TX - RJ-45
- Encryption Algorithm
- WPA, WEP
- FCC, RoHS
- White
- Power Device
- External
- Voltage Required
- AC 120/230 V
- Software Included
- Drivers & Utilities
- OS Required
- 5.8 cm
- 7.2 cm
- 2.5 cm
- 65 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 70% (non-condensing)
