StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI
Quicklinx: 84M5WS00 Mfr#: ICUSB232FTN
30 In Stock
£25.80 ex VAT
£30.96 inc VAT
Add a Null Modem RS232 serial port to your laptop or desktop computer through USB. The ICUSB232FTN FTDI USB to Null Modem Serial Adapter Cable (1 port) converts an available USB 1.1 or 2.0 port into an RS232 Null Modem serial DB9 port, solving DCE/DTE conflicts directly, without requiring additional cross-wired serial cables or adapters.
This compact adapter features COM retention, allowing the same COM port value to automatically be re-assigned to the port if the cable is disconnected and re-connected to the host computer, or if the system is rebooted. The integrated FTDI chipset supports additional customization, advanced features, and compatibility not necessarily offered by other solutions.
The USB to Null Modem adapter is compatible with a broad list of operating systems including Windows, Windows CE, Mac OS and Linux, making it easier to integrate into mixed environments.
StarTech.com USB to Serial RS232 Adapter - DB9 Serial DCE Adapter Cable with FTDI - Null Modem - USB 1.1 / 2.0 - Bus-Powered (ICUSB232FTN) - serial adapter - USB 2.0 - RS-232
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232
4.2 cm x 4.5 cm x 2.2 cm
Length
1.8 m
140 g
RS-232
Data Transfer Rate
921.6 Kbps
USB 1.1, USB 2.0
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 3.0 or later, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
Serial adapter
External
USB 2.0
Ports
RS-232
Wired
RS-232
Data Transfer Rate
921.6 Kbps
USB powered
USB 1.1, USB 2.0
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB - 4 pin USB Type A
1 x USB cable (integrated) - 1.7 m
FCC, RoHS
4.2 cm
4.5 cm
2.2 cm
Length
1.8 m
140 g
55 °C
5 - 95%
84M5 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £22.01
84M5 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £32.63
84M5 StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £14.05
84M5 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.62
84M5 StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M In Stock £20.82
84M5 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £96.96
84M5 StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £25.80
84M5 StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £91.11
84M5 StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £152.14
84M5 StarTech.com USB to RS232 Serial Adapter In Stock £16.68
84M5 StarTech.com 4 Port USB to Serial Hub In Stock £78.99
84M5 StarTech.com UCB C to Serial Adapter In Stock £17.40
84M5 StarTech.com 4-Port USB to Serial Adapter In Stock £218.26
84M5 StarTech.com 8-Port USB to Serial Adapter In Stock £350.31
