StarTech.com 1 Port USB 2.0 over Cat5 / Cat6 Ethernet Extender - up to 330ft (100m)
Quicklinx: 87PDWS00 Mfr#: USB2001EXT2
Type: Extender
13 in stock
£264.25 ex VAT
£317.10 inc VAT
Extend one USB 2.0 connection up to 330ft away from the computer over Cat5 or Cat6 cable. The USB2001EXT2 USB over Cat5/Cat6 Extender lets you extend a USB 2.0 connection over distances of up to 100-meters (330-feet), over standard Cat5 or Cat6 Ethernet cabling.
Backward compatible with USB 1.x devices, the extender enables almost any kind of USB device to be placed at remote locations away from the host computer system.
With data bandwidth of up to 480 Mbps and no software installation required, the USB extender offers a fast, easy, and versatile solution for business or industrial applications with durable metal housing, an included surface-mounting bracket kit, and simple plug-and-play installation.
Plus, the extender provides up to the full 500 mA of power (with the use of an external power adapter at the remote end) allowing for greater compatibility with bus-powered USB devices.
StarTech.com 1 Port USB over Cat5 Cat6 Ethernet Extender up to 330ft (100m) - USB extender - USB 2.0
USB extender
External
Data Transfer Rate
480 Mbps
USB 2.0
Max Transfer Distance
100 m
AC 120/230 V
Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits)
P/N: SVA5M4NEUA
USB extender
External
Wired
USB 2.0
Data Transfer Rate
480 Mbps
100 m
Status Indicators
Power, active, host, link/activity, USB
USB 2.0
1 x USB 2.0 - Type A female , 1 x USB 2.0 - Type B female , 2 x - RJ-45 female
FCC, RoHS
External power adapter
AC 120/230 V
50 °C
20 - 90%
P/N: SVA5M4NEUA
87PD StarTech.com 3 ft Mini USB 2.0 Cable - A to Mini B In Stock £3.18
87PD StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B In Stock £3.31
87PD StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
87PD StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.81
87PD StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
87PD StarTech.com 6in Mini USB 2.0 Cable - A to Mini B In Stock £3.07
87PD StarTech.com 3 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.92
87PD StarTech.com 1000ft Roll Blue Stranded Cat 6 Patch Cable In Stock £239.80
87PD StarTech.com 2 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m) In Stock £328.95
87PD StarTech.com 4 Port USB 2.0 Extender over Cat5 or Cat6 - Up to 330 ft (100m) In Stock £316.75
87PD StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) In Stock £70.01
87PD StarTech.com 1 Port USB 2.0 over Cat5 / Cat6 Ethernet Extender - up to 330ft (100m) In Stock £264.25
87PD StarTech.com 1000 ft Bulk Roll of Gray CMR Cat5e Solid UTP Cable In Stock £121.35
87PD StarTech.com 4 Port USB 2.0 over Gigabit LAN or Direct Cat5e / Cat6 Ethernet Extender - up to 330 ft In Stock £427.16
87PD StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) In Stock £129.39
87PD StarTech.com 1 Port USB 2.0 Extender Kit In Stock £100.14
87PD StarTech.com 1 Port USB 2.0 Extender Kit In Stock £296.22
Type: Extender
Price Range Ex VAT: 150 - 300
