Connect a USB 2.0 device to your computer over long distances, using this single-port USB extender. Here's a versatile and cost-effective USB 2.0 extender. It gives you the freedom you need to place your USB device further away, making it perfect for the homes, offices, classrooms, and many other environments. Now, you can easily access and use your USB 2.0 device in a remote location, up to 165 ft. (50 m) away, using Cat5 or Cat6 cable.
This USB extender overcomes the 16 ft. cable length limitations of traditional USB 2.0 cables, so you can create a more efficient, more flexible workspace.
It's an inexpensive USB-to-Ethernet solution that's ideal for virtually any USB 2.0 device. You can connect a webcam at the back of a classroom, or a printer in another room at the office, all up to 50 m away from your host computer.
Plus, with a power adapter included for the remote unit, you can connect power-hungry USB devices such as external hard drives.
Unlike other USB extenders that feature a plastic housing, this extender offers a metal casing that offers rugged durability. Whether the extender is installed in a permanent location, or will be moved from place to place, it gives you the peace of mind that your USB peripheral remains connected and accessible, right where you need it.
The USB 2.0-over-Cat5-or-Cat6 extender is OS independent, so it supports a variety of operating systems. Setup is easy with no additional drivers or software required, and the extender is backward compatible with USB 1.1 and 1.0 peripherals.
Flexible connectivity options
This extender features USB Type-A and Type-B connectors, providing versatility for various devices such as printers, scanners, and external drives. -
Extended reach
With a maximum transfer distance of 50 m, users can position devices farther from the computer while maintaining a reliable connection, ideal for larger setups. -
Reliable data transmission
Utilizing CAT 5e/6 cables, this USB extender ensures effective data transfer rates in compliance with USB standards, minimizing connection interruptions and data loss. -
Power support
The inclusion of an external power adapter allows for consistent operation of connected devices, offering convenience in setups requiring additional power.
- StarTech.com USB 2.0 Extender over Cat5e/Cat6 Cable (RJ45), Up to 165ft (50m), High Speed USB Port Extender Adapter Kit, Powered, USB over Ethernet Cable Extender, 480Mbps, Metal Housing - Power/Link/Activity LEDs (USB2001EXTV) - USB extender - USB 2.0
- USB extender
- Form Factor
- External
- Data Link Protocol
- USB 2.0
- Transmission Medium
- CAT 5e/6
- Max Transfer Distance
- 50 m
- 2-year warranty
- Designed For
- P/N: SVA5N3NEUA
- USB extender
- Form Factor
- External
- Connectivity Technology
- Wired
- USB 2.0
- 50 m
- Status Indicators
- Link OK
- USB 1.1, USB 2.0
- 1 x (local unit) - RJ-45 female , 1 x (remote unit) - RJ-45 female , 1 x USB 2.0 (remote unit) - Type A female , 1 x micro-USB (local unit) - Type B female
- Included Accessories
- 8 rubber feet
- Cables Included
- 1 x USB cable , 1 x network cable
- Power Device
- External power adapter
- Limited warranty - 2 years
- Designed For
- P/N: SVA5N3NEUA
StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) | In Stock | £102.87 |
StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable | In Stock | £205.95 |
StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) | In Stock | £146.84 |
StarTech.com 1 Port USB 2.0 Extender Kit | In Stock | £127.12 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.21 |
