StarTech.com 1 Port USB 2.0 Extender Kit
Quicklinx: CQSLWS00 Mfr#: USB2001EXTV
Type: USB Extender
Interface: USB 2.0
Speed: 480Mbps
Ports: 1
Form Factor: External
£130.30 ex VAT
£156.36 inc VAT
Connect a USB 2.0 device to your computer over long distances, using this single-port USB extender. Here's a versatile and cost-effective USB 2.0 extender. It gives you the freedom you need to place your USB device further away, making it perfect for the homes, offices, classrooms, and many other environments. Now, you can easily access and use your USB 2.0 device in a remote location, up to 165 ft. (50 m) away, using Cat5 or Cat6 cable.
This USB extender overcomes the 16 ft. cable length limitations of traditional USB 2.0 cables, so you can create a more efficient, more flexible workspace.
It's an inexpensive USB-to-Ethernet solution that's ideal for virtually any USB 2.0 device. You can connect a webcam at the back of a classroom, or a printer in another room at the office, all up to 50 m away from your host computer.
Plus, with a power adapter included for the remote unit, you can connect power-hungry USB devices such as external hard drives.
Unlike other USB extenders that feature a plastic housing, this extender offers a metal casing that offers rugged durability. Whether the extender is installed in a permanent location, or will be moved from place to place, it gives you the peace of mind that your USB peripheral remains connected and accessible, right where you need it.
The USB 2.0-over-Cat5-or-Cat6 extender is OS independent, so it supports a variety of operating systems. Setup is easy with no additional drivers or software required, and the extender is backward compatible with USB 1.1 and 1.0 peripherals.
  • Flexible connectivity options
    This extender features USB Type-A and Type-B connectors, providing versatility for various devices such as printers, scanners, and external drives.
  • Extended reach
    With a maximum transfer distance of 50 m, users can position devices farther from the computer while maintaining a reliable connection, ideal for larger setups.
  • Reliable data transmission
    Utilizing CAT 5e/6 cables, this USB extender ensures effective data transfer rates in compliance with USB standards, minimizing connection interruptions and data loss.
  • Power support
    The inclusion of an external power adapter allows for consistent operation of connected devices, offering convenience in setups requiring additional power.
Startech USB 2.0 Extender over Cat5e/Cat6 Cable (RJ45), Up to 165ft (50m), High Speed USB Port Extender Adapter Kit, Powered, USB over Ethernet Cable Extender, 480Mbps, Metal Housing - Power/Link/Activity LEDs (USB2001EXTV) - USB extender - USB 2.0
USB extender
External
USB 2.0
Transmission Medium
CAT 5e/6
Max Transfer Distance
50 m
P/N: SVA5N3NEUA
USB extender
External
Wired
USB 2.0
50 m
Status Indicators
Link OK
USB 1.1, USB 2.0
1 x (local unit) - RJ-45 female , 1 x (remote unit) - RJ-45 female , 1 x USB 2.0 (remote unit) - Type A female , 1 x micro-USB (local unit) - Type B female
8 rubber feet
1 x USB cable , 1 x network cable
External power adapter
P/N: SVA5N3NEUA
CQSL StarTech.com 100 ft Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £31.89
CQSL StarTech.com 1 Port USB over Cat5 / Cat6 Ethernet Extender - up to 131ft (40m) In Stock £105.43
CQSL StarTech.com 1000 ft Bulk Roll of Blue CMR Cat5e Solid UTP Cable In Stock £284.02
CQSL StarTech.com 4-port USB 2.0 Over Cat5 or Cat6 Extender (50m) In Stock £150.50
CQSL StarTech.com 1 Port USB 2.0 Extender Kit In Stock £130.30
CQSL StarTech.com DC Power Adapter - 5V, 3A In Stock £12.31
Type: USB Extender
Interface: USB 2.0
Speed: 480Mbps
Ports: 1
