Scale your 10/100 Mbps Ethernet network 1km over RJ11 phone lines and remotely connect four RJ45 network devices. The 1-port to 4-port VDSL2 Ethernet extender kit lets you connect up to 4 remote network segments or devices to your network, using RJ11 phone cable.
This VDSL2 extender is easy to use and integrates a 4-port Ethernet switch on the receiver unit, which reduces the expense of purchasing additional network switches or routers.
The extender reduces the hassle of networking your isolated devices or server rooms by overcoming the 330ft (100m) distance limitations of common CATx Ethernet cable. It's perfect for connecting remote IP cameras or user workstations using single-pair copper wire such as telephone cable.
The versatile extender spans your network at distances up to 3300ft (1000m) at 40Mbps, or 1000ft (300m) at 100Mbps throughput.
With a built-in 4-port Ethernet switch, you don't have to purchase additional networking equipment at the remote location. Plus, you can deliver network access across the existing phone line infrastructure for added cost savings, or simply use a single point-to-point RJ11 cable.
The reliable extender is ideal for networking separate buildings at the same location, or for use in older buildings that only have plain old telephone service (POTS). It gives you more network connectivity options in locations where standard CATx wired or wireless access is unavailable or unreliable.
This extender kit is the perfect all-in-one extension solution. With an integrated DIP switch as well as web-based customization, you have all the tools needed for simple yet effective network extension and management.
The web-interface lets you tweak settings such as IP, port, and MAC address filtering, and to get you up and running quickly there's no driver or software installation required.
- StarTech.com 1-Port to 4-Port VDSL2 Ethernet Extender Kit Over Single Pair Wire - short-haul modem - 10Mb LAN, 100Mb LAN, Ethernet over VDSL2
- Short-haul modem
- Ports Qty
- 4
- Form Factor
- External
- Cabling Type
- 10Base-T, 100Base-TX
- Data Link Protocol
- Remote Management Protocol
- HTTP
- Max Transfer Distance
- 1 km
- Power
- AC 120/230 V
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Short-haul modem
- Form Factor
- External
- Black
- Ports Qty
- 4
- Connectivity Technology
- Wired
- Cabling Type
- HTTP
- 1 km
- Flow control, full duplex capability, firewall protection, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IP address filtering, surge protection, Quality of Service (QoS), plastic housing, bandwidth control, port configuration, Strict Priority (SP), 4KV ESD Protector, Type of Service (ToS), DiffServ Code Point (DSCP) support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
- 1 x Ethernet 10Base-T/100Base-TX - RJ-45 , 4 x Ethernet 10Base-T/100Base-TX - RJ-45
- Cables Included
- 2 x network cable
- IEC 61000-4-2, EN 61000-4-5, FCC, RoHS
- Power Device
- External power adapter
- Installed Qty
- 2
- Voltage Required
- AC 120/230 V
- 2.5 Watt
- Limited warranty - 2 years
- Designed For
