Control a server or PC remotely over the Internet, with built-in remote power management and RS232. The SV1108IPPWGB 1 Port Remote Control IP KVM Switch with IP Power Control and Virtual Media lets you control a USB or PS/2 server remotely over a LAN or the Internet, and access the remote power switch feature to power on and off as necessary.
The 1 port KVM over IP includes all necessary KVM cables, and offers KVM control from the BIOS-level onward. Reboot, monitor the entire boot process, and interact with your connected system easily, while the integrated single-port power switch allows you to power the server on or off remotely. RS232 support also lets you connect to a serial console device via Telnet or SSH.
Virtual Media lets you execute files via USB from the remote console as if they were local to the connected server. Perfect for remote driver updates, patches, application or OS installation.
The Java-based browser utility ensures the IP remote control unit is compatible with many current web browsers, and almost any operating system on the market.
Multiple integrated security features ensure a reliable single port IP KVM connection, including password-protection, IP/MAC address filtering, external authentication (RADIUS, LDAP, LDAPS, Active Directory) and advanced encryption (56-bit DES, 168-bit 3DES, 256-bit AES, 128-bit RC4).
- StarTech.com 1 Port Server Remote Control IP KVM Switch w/ IP Power Control - KVM switch
- KVM switch
- Subtype
- KVM
- Remote Management Protocol
- HTTP, HTTPS
- 128-bit encryption, DHCP support, MAC address filtering
- 8.1 cm x 30.8 cm x 4.2 cm
- 860 g
- Black
- Localisation
- United Kingdom
- 2-year warranty
- KVM switch
- Enclosure Type
- Desktop
- Subtype
- KVM
- Keyboard / Mouse Interface
- PS/2, USB
- HTTP, HTTPS
- Encryption Algorithm
- DES, Triple DES, RC4, AES, 128-bit WEP, SSL
- Authentication Method
- Secure Shell (SSH)
- Max Resolution
- 1600 x 1200 @ 60 Hz
- Status Indicators
- Power, link/activity
- 2 x VGA HD-15 , 2 x keyboard (PS/2) , 2 x mouse (PS/2) , 3 x USB , 1 x mini-USB Type B , 1 x serial (RS-232) DB-9 , 1 x RJ-45
- Power Device
- External power adapter
- Black
- Cables Included
- 1 x keyboard / mouse / video cable
- Rack Mounting Kit
- Included
- Localisation
- United Kingdom
- 8.1 cm
- 30.8 cm
- 4.2 cm
- 860 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 0 - 80% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
