Connect to, configure and remotely manage an RS-232 serial device over an IP network. The NETRS2321POE 1 Port RS232 Serial Ethernet Device Server - PoE (Power Over Ethernet) allows you to install your RS232 devices anywhere on your TCP/IP Ethernet WAN/LAN, and access them as if they were right beside you - even over the Internet!
The Serial Device Server is designed to function seamlessly with your other integrated and add-on serial ports as if they were right inside your computer. Perfect for industrial automation, security, Point of Sale, or any long-range serial application, delivering reliable performance in any environment.
The Ethernet/serial device server supports PoE (Power over Ethernet) when connected to a PoE compliant device - eliminating the need for an external power supply and outlet, and making it easier to situate the device server as needed.
- StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet - Serial over IP Device Server Adapter - PoE-Powered (NETRS2321POE) - device server
- Device server
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, RS-232
- Power Over Ethernet (PoE) Supported
- PoE
- 6.6 cm x 10.7 cm x 2.5 cm
- 480 g
- 2-year warranty
- Designed For
- P/N: IES51000POE, IES61002POE, IES81000POE, IES8100POE, POEINJ1G, POEINJ1GW, POEINJ2GI, POEINJ4G, SVA12M5NA, UPOESPLT1G
- Device server
- 6.6 cm
- 10.7 cm
- 2.5 cm
- 480 g
- Enclosure Colour
- Black
- Form Factor
- External
- Connectivity Technology
- Wired
- Data Transfer Rate
- 115.2 Kbps
- TCP/IP, UDP/IP, ICMP/IP
- Remote Management Protocol
- HTTP
- Status Indicators
- Port transmission speed, link OK, link/activity
- DHCP support, ARP support
- 1 x 100Base-TX - RJ-45 , 1 x RS-232 - DB-9
- FCC, RoHS
- PoE
- Power Device
- External power adapter
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
- Designed For
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £14.05 |
StarTech.com Slimline DB9 Serial Gender Changer - F/F | In Stock | £4.64 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.58 |
StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet | In Stock | £120.78 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.02 |
