StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet
Quicklinx: 98NNWS00 Mfr#: NETRS2321POE
Type: PoE Kit
£117.45 ex VAT
£140.94 inc VAT
Connect to, configure and remotely manage an RS-232 serial device over an IP network. The NETRS2321POE 1 Port RS232 Serial Ethernet Device Server - PoE (Power Over Ethernet) allows you to install your RS232 devices anywhere on your TCP/IP Ethernet WAN/LAN, and access them as if they were right beside you - even over the Internet!
The Serial Device Server is designed to function seamlessly with your other integrated and add-on serial ports as if they were right inside your computer. Perfect for industrial automation, security, Point of Sale, or any long-range serial application, delivering reliable performance in any environment.
The Ethernet/serial device server supports PoE (Power over Ethernet) when connected to a PoE compliant device - eliminating the need for an external power supply and outlet, and making it easier to situate the device server as needed.
StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet - Serial over IP Device Server Adapter - PoE-Powered (NETRS2321POE) - device server
Device server
External
Ethernet, Fast Ethernet, RS-232
Power Over Ethernet (PoE) Supported
PoE
6.6 cm x 10.7 cm x 2.5 cm
480 g
P/N: IES51000POE, IES61002POE, IES81000POE, IES8100POE, POEINJ1G, POEINJ1GW, POEINJ2GI, POEINJ4G, SVA12M5NA, UPOESPLT1G
Device server
6.6 cm
10.7 cm
2.5 cm
480 g
Enclosure Colour
External
Wired
Data Transfer Rate
115.2 Kbps
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP
Remote Management Protocol
HTTP
Status Indicators
Port transmission speed, link OK, link/activity
DHCP support, ARP support
1 x 100Base-TX - RJ-45 , 1 x RS-232 - DB-9
FCC, RoHS
PoE
External power adapter
55 °C
5 - 95%
98NN StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £15.41
98NN StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.77
98NN StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
98NN StarTech.com DC Power Adapter - 12V, 5A In Stock £44.00
Type: PoE Kit
