This RS232 Serial Adapter Card lets you add an RS232 DB9 serial port to your computer through a PCI Express (PCIe) slot. It enables you to interact with serial devices such as card readers, printers, PIN pads, and modems, at speeds of up-to 921.4Kbps.
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments. The card comes pre-configured with a low-profile bracket, and includes an optional full-profile bracket, so installation is easy regardless of the case form factor.
This PCIe to serial adapter supports the following features: Compatible with industry standard 16950 UART; Supports max baud rate of up-to 921.4Kbps; Provides 5/12V power output on Pin 9 when external power is connected; 128-byte depth FIFO per transmitter and receiver; Supports 9, 8, 7, 6, 5 data bits; Asix AX99100 chipset; PCI Express 1.1 compliant.
Maximum Compatibility
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments. The card comes pre-configured with a low-profile bracket, and includes an optional full-profile bracket, so installation is easy regardless of the case form factor. -
Experience Optimal Technology
This PCIe to serial adapter supports the following features: • Compatible with industry standard 16950 UART • Supports max baud rate of up-to 921.4Kbps • Provides 5/12V power output on Pin 9 when external power is connected • 128-byte depth FIFO per transmitter and receiver • Supports 9, 8, 7, 6, 5 data bits • Asix AX99100 chipset • PCI Express 1.1 compliant PEX1S953LP is backed by a StarTech.com lifetime warranty and free lifetime technical support.
- StarTech.com 1-port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Host Controller Card, PCIe to Serial DB9 COM Port, 16950 UART, Low Profile Expansion Card, Windows/macOS/Linux - Full/Low-Profile (PEX1S953LP) - serial adapter - PCIe - RS-232 x 1
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- PCI Specification Revision
- PCIe 1.1
- Ports
- RS-232 x 1
- 4.62 cm x 9.8 cm x 1.8 cm
- 46.2 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- Processor
- ASIX AX99100
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux 2.4 - 2.6.x
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI Express x1
- PCIe 1.1
- Ports
- RS-232 x 1
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- Full duplex mode, 256-byte FIFO
Processor / Memory
- Processor
- ASIX AX99100
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Full-height bracket
- WHQL, FCC, RoHS, WEEE
- OS Required
- 4.62 cm
- 9.8 cm
- 1.8 cm
- 46.2 g
- Shipping Weight
- 124.6 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 20 - 80%
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.51 |
StarTech.com 2 Port PCI Express RS232 Serial Adapter Card | In Stock | £37.07 |
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £159.61 |
StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo | In Stock | £34.94 |
StarTech.com Serial/Parallel PCI Card | In Stock | £19.05 |
StarTech.com PCIe Dual Serial Port Card | In Stock | £44.02 |
