StarTech.com 1 Port RS232 Serial Adapter Card with 16950 UART - 921.4Kbps
Quicklinx: FC03WS00 Mfr#: PEX1S953LP
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Serial adapter
£34.74 ex VAT
£41.68 inc VAT
This RS232 Serial Adapter Card lets you add an RS232 DB9 serial port to your computer through a PCI Express (PCIe) slot. It enables you to interact with serial devices such as card readers, printers, PIN pads, and modems, at speeds of up-to 921.4Kbps.
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments. The card comes pre-configured with a low-profile bracket, and includes an optional full-profile bracket, so installation is easy regardless of the case form factor.
This PCIe to serial adapter supports the following features: Compatible with industry standard 16950 UART; Supports max baud rate of up-to 921.4Kbps; Provides 5/12V power output on Pin 9 when external power is connected; 128-byte depth FIFO per transmitter and receiver; Supports 9, 8, 7, 6, 5 data bits; Asix AX99100 chipset; PCI Express 1.1 compliant.
  • Maximum Compatibility
  • Experience Optimal Technology
    This PCIe to serial adapter supports the following features: • Compatible with industry standard 16950 UART • Supports max baud rate of up-to 921.4Kbps • Provides 5/12V power output on Pin 9 when external power is connected • 128-byte depth FIFO per transmitter and receiver • Supports 9, 8, 7, 6, 5 data bits • Asix AX99100 chipset • PCI Express 1.1 compliant PEX1S953LP is backed by a StarTech.com lifetime warranty and free lifetime technical support.
Startech 1-port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Host Controller Card, PCIe to Serial DB9 COM Port, 16950 UART, Low Profile Expansion Card, Windows/macOS/Linux - Full/Low-Profile (PEX1S953LP) - serial adapter - PCI Express x1 - RS-232 x 1
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
PCI Specification Revision
PCIe 1.1
Ports
RS-232 x 1
4.62 cm x 9.8 cm x 1.8 cm
46.2 g
RS-232
Data Transfer Rate
921.6 Kbps
ASIX AX99100
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux 2.4 - 2.6.x
Serial adapter
PCI Express x1
PCIe 1.1
Ports
RS-232 x 1
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Full duplex mode, 256-byte FIFO
Processor / Memory
ASIX AX99100
1 x RS-232 - 9 pin D-Sub (DB-9)
Full-height bracket
WHQL, FCC, RoHS, WEEE
4.62 cm
9.8 cm
1.8 cm
46.2 g
Shipping Weight
124.6 g
Limited warranty - lifetime
70 °C
20 - 80%
FC03 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
FC03 StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £36.05
FC03 StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £155.21
FC03 StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo In Stock £33.98
FC03 StarTech.com Serial/Parallel PCI Card In Stock £20.41
FC03 StarTech.com 1-Prt PCI Express Serial Card In Stock £36.98
FC03 StarTech.com PCIe Dual Serial Port Card In Stock £38.53
FC03 StarTech.com PCIe Dual Serial Port Card In Stock £42.80
Protocol: RS-232
