StarTech.com 1 Port RS-232 Serial to IP Ethernet Device Server - DIN Rail Mountable
Quicklinx: 9M79WS00 Mfr#: NETRS232
36 in stock
£65.59 ex VAT
£78.70 inc VAT
A cost-effective way to connect, configure, and manage a remote RS-232 serial device over an IP network. This 1-Port Serial Device Server lets you remotely access and manage an RS232 serial device over a local or wide area network (LAN/WAN), for a simple and cost-effective serial-over-IP control solution.
For installation flexibility across a variety of environments, you can power the device server using the provided 12V DC power adapter, or using the integrated 10~30V DC terminal block.
To help ensure reliable performance and prevent possible damage, the serial device server offers 15KV ESD (Electrostatic Discharge) protection, so you can rest assured that the device server won't become damaged due to externally generated ESD.
This highly-customizable device server is easy to configure to suit your application. For easy setup, Windows users can use the provided Virtual COM port software, or the versatile web-based interface.
The RS232 device server supports Telnet (an operating system independent communication protocol), so it can be integrated into mixed OS environments (Windows, Mac, Linux).
StarTech.com 1 Port RS-232 Serial to IP Ethernet Device Server - device server
Device server
External
Ethernet, RS-232
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10
AC 100/230 V
5.4 cm x 8.6 cm x 2.3 cm
65 g
P/N: IES101002SFP
Device server
5.4 cm
8.6 cm
2.3 cm
65 g
Enclosure Colour
External
Wired
Data Transfer Rate
230.4 Kbps
Ethernet, RS-232
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, DHCP
Remote Management Protocol
HTTP
Status Indicators
Power, LAN, link/activity
DHCP support, ARP support, auto-uplink (auto MDI/MDI-X), surge protection, static IP mode
IEEE 802.3, IEEE 802.3u
1 x RS-232 - DB-9 , 1 x 100Base-TX - RJ-45
FCC, RoHS
External power adapter
AC 100/230 V
1.45 Watt
Software Included
Drivers & Utilities
60 °C
0 - 90%
P/N: IES101002SFP
9M79 StarTech.com Slimline DB9 Serial Gender Changer - F/F In Stock £4.56
9M79 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.19
9M79 StarTech.com 1 Port RS232 Serial to IP Ethernet Converter / Device Server - Aluminum In Stock £115.78
9M79 StarTech.com 1 Port RS232 Serial Ethernet Device Server - PoE Power Over Ethernet In Stock £118.13
9M79 StarTech.com 1 Port RS-232 Serial to IP Ethernet Device Server - DIN Rail Mountable In Stock £65.59
Stock Status: In stock
